Bob Ptaker Guest
Posted: Mon Aug 27, 2012 5:24 pm Post subject: Canon C130. Very hard to get the start key to print copies |
PROBLEM: Have a Canon C130 copier. It is very hard to get the start key to print copies. You have to press real hard, sometimes pressing different points on the button gets it to print.
ONE SOLUTION OFFERED: "Odds are that you will have to replace the control panel. Or if you are not scared to take the copier apart. You can fix it your self.... The problem is that the solder connection for the switch is broken from the PCB.... If you can take the control panel off and solder the connection for the switch, you will save some money"
REQUEST: The service manual so I can take apart the copier and get at the control panel.
Any help you can give me would be appreciated.
Thank you
Bob[code][/code] |
DMM7510 Firmware v1.1.0f Keithley • phb9nq20t phd9nq20t php9nq20t 2 Philips • ss8550 Secos • MaxLine ІІ 250 GB maxtor • tip3055 Bourns • PT-LB10NTU ALL SVC panasonic • 04-lubrication system Honda • Adj Di181 020 Minolta • QS-6 Alesis • stv355 CHOV •
