mixerpilot Guest
Posted: Thu Jan 19, 2006 9:04 am Post subject: jvc av36950/no picture good sound good tunerhelp please!!!!! |
I have a 36 inch jvc tv I bought in ninty eight its been perfect. Until wife was watching tv one night said screen went from fine to thin horizontal line/sound and tuner fine. I turned it on got normal picture for a minute then it went to horizontal thin line. sound and tuning of different channels seems to work when I turned off set a white dot appeared for a second. second time I turned it on no raster at all sound still good no thin horizontal line no on screen menus vol,clock,,,,etc. could any one tell me what I should ck vertical deflection, diodes,caps,etc. any help would be greatly appreciated thanx alot kenny |
Posted: Thu Jan 19, 2006 2:48 pm Post subject: Re: jvc av36950/no picture good sound good tunerhelp please! |
mixerpilot wrote: | I have a 36 inch jvc tv I bought in ninty eight its been perfect. Until wife was watching tv one night said screen went from fine to thin horizontal line/sound and tuner fine. I turned it on got normal picture for a minute then it went to horizontal thin line. sound and tuning of different channels seems to work when I turned off set a white dot appeared for a second. second time I turned it on no raster at all sound still good no thin horizontal line no on screen menus vol,clock,,,,etc. could any one tell me what I should ck vertical deflection, diodes,caps,etc. any help would be greatly appreciated thanx alot kenny | first resolder the vertical section..for possible loose connection 2nd replace capacitors,100 uf/50v,1000 uf/35v,1 uf/50v and try replacing vert. ic.also check the voltage at pin 2 it must be atleast 12v..ok? |
Posted: Thu Jan 19, 2006 2:53 pm Post subject: |
ok..1st try resoldering the vertical section for possible loose connection 2nd try replacing capacitors in the vertical 100 uf/50v,1000 uf /50v etc.3rd check pin 2 voltage of the vertical ic it should be around 12v.if not replaced the ic..ok? |
ipp90r340c3 1[1].0 Infineon • Panel CHIMEI INNOLUX N121I6-L02 0 [DS] . • 3310 nokia • SLPG490 Technics • 626A HP • TPM142ELA SB-EX-SI 1423472749 Philips • 29TJ70 01 Erisson • 8310-6510 Cable Nokia • GDM-400PS Sony • SCT55A Samsung •
