nerang@ki
Posted: Mon Jan 23, 2006 9:47 pm Post subject: NationalVCR NVG7A Service manual & circuit and data shee |
I desparately need to find the circuit ,data sheets and any service manual for this trusty old warrior of a VCR.
On / off / eject red and green LED' not lighting up now. Test out OK with multi- meter and each of the three fuses are fine.
Something is suddenly sick. _________________ Arthur&Son |
Posted: Mon Jan 23, 2006 10:57 pm Post subject: |
TRY REPLACING THE STK PSU IC, COMMON FAULT IS LOSS OF ONE OF THE SUPPLY RAILS FROM THE IC, ON SET THIS OLD WOULD ALSO B WORTH REPLACING ALL ELECTROLYTIC CAPS IN PSU WHILE IT IS IN BITS. |
nerank@ki Guest
Posted: Sat Jan 28, 2006 3:07 pm Post subject: NationalVCR NVG7A Service manual & circuit and data shee |
Thanks Gary for the suggestions.
I removed the psu unit and it tests OK.
So I'm a bit lost without a circuit to explore what other possibilities need exploring.
Any manual / datasheet / circuit for the NationalVCR NVG7A would be very useful as the tuner in this old VCR always gave a very strong signal.
( Much better than many of the newer ones available ) particularly as main digital terrestrial signal often drops out. |
Posted: Mon Jan 30, 2006 5:10 pm Post subject: |
the psu needs to be tested while connected to the vcr as the supply rails will often only be low while under load, it is best to check the supply rails on the secondary with an oscilloscope as this will show which rails are incorrectly smoothed with hf ripple, DO NOT rely on a multimeter with this fault. |
41FH6817E-01A 2344 Oct87 Fujitsu • Samsung PN60E8000GFXZA fast track guide • AJ-CV3400 Akai • lg plasma training 20072 269 LG • OBSJ DT ug HP • TC70 DUCRETET • tipl761 . Electronic Components Datashee • CDC-MP3 Aiwa • CS-P55 (W) Aiwa • carradio GM-X412 Pioneer •
