zodehala
Posted: Wed Aug 06, 2008 9:54 pm Post subject: what is its name ? |
as you know when bios is crached we can update it using bois programmer
but some mainborad's bios is soldered on board . as far as i remeber it can be updated using a card which is pluged into PCI
do you know what this card name is ? |
Posted: Thu Aug 07, 2008 3:57 am Post subject: |
| you can always solder cables on pins and do a hot swap that way. |
Posted: Thu Aug 07, 2008 8:48 am Post subject: |
In case of a PC motherboard where the bios eprom is soldered, there is usually a protected area of the eprom that cannot usually be corrupted, which contains a recovery bios code, not enough to startup the motherboard in the conventional way but enough to load a correct bios file from some kind of media (diskette, USB stick etc) and reprogram the bios eprom.
Begin with studying the manual for the motherboard and any relevant information that can be found on the motherboard manufacturer's website.
Unless this kind of recovery is possible, the easiest way is to de-solder the eprom and connect it to a programmer. |
CDJ-500-G-RRV1087.part2 Pioneer • BIOS and Kernel Developer 2527s Guide fo • STR-W555 panasonic • 92 VCR Sanyo • php50n06lt 3 Philips • B53-0037-00-EVPL Kenwood • Nordmende 2170A Nordmende • NIC [snap-in] NRLR Series NIC • tx-28ck2c tx-28h1c tx-28-mb1c panasonic • CT M486MK2 teac •
