Drdave
Joined: 11 Jun 2009 Posts: 24 Location: South Florida
Posted: Sat Oct 03, 2009 4:18 pm Post subject: Thin black Horz. line across new Panasonic Plasma |
DrDave needs Help!
Purchased about a month ago a new Panasonic (TC-50PS14) Plasma.
Turned TV on today to watch some football an discovered a very thin black Horz. line about 6 inches from bottom of the display.
Is this a common display or display driver problem? Any way to reset this set or is it time to call for warranty service?
Anyone with info on this type of failure or a fix would be greatly appreciated.
Thanks in advance |
Posted: Sun Oct 04, 2009 12:17 am Post subject: |
Get it looked at by the shop you bought it from
1 month new and already faulty.
Should have at least 1 to 2 years warranty on it. |
Posted: Sun Oct 04, 2009 4:57 am Post subject: |
Unless it was a "pawn" shop!  _________________ You're over there, I'm over here. |
Posted: Sun Oct 04, 2009 4:06 pm Post subject: |
| Call for service 10 to 1 it's the panel. |
Drdave
Posted: Sun Oct 04, 2009 5:53 pm Post subject: Thin black Horz. line across new Panasonic Plasma |
Called for service.They had me do reset,etc. Line was still there.Panasonic set up a service call for this Wednesday.Turned set off left the house for a couple of hours.Came home turned it back on No line.The problem hasn't come back as yet and must be intermittent.
The question is if the line doesn't come back before Wednesday should I still let them come out?or cancel and have them save the trouble report. |
Pentode
Posted: Sun Oct 04, 2009 7:30 pm Post subject: |
You don't want to have a repeat performance when the warranty runs out, better to follow the good advice others have posted...
... simply tell them the fault is intermittent.... it comes and goes as of it wants, I have seen this fault in Plasma and LCD displays, it could be something serious like a chip faulty or a badly fitted ribbon cable, if it's new you don't wanna be waiting till the warranty runs out and wait of them telling you, "you want a new display mate" - they don't come cheap.
Dave. |
Posted: Mon Oct 05, 2009 1:35 am Post subject: |
| A vertical line is the bottom buffer board. The tech will probably disconnect the ribbon cable and clean the contacts. This may or may not fix it. |
Drdave
Posted: Tue Oct 06, 2009 12:46 pm Post subject: Thin Black Line |
As always. Thanks for all the input.
The black line hasn't reappeared since the weekend but still have Panasonic scheduled to come out and check it out anyway .Will let you know what they find if anything.Thanks again. |
Drdave
Posted: Wed Oct 14, 2009 1:02 pm Post subject: Update on the thin black line. |
Panasonic service replaced a board even though the set was working just fine when he was here. He did say they will replace the set if the problem comes back. I give Panasonic High marks for the quality of service they provided . |
