Posted: Tue Nov 25, 2008 4:17 pm Post subject: Dell Inspiron 1150 Motherboard Circuit Layout |
I have just replaced the power jack connection on my laptop due to false contact or cold weld. Seems the sawder will not make contact to the eroded board connection. I was looking for a circuit board layout or blueprint so that I can sawder a wire and jump it to the next good connection. Can anyone help? |
Billy Mays Guest
Posted: Thu Oct 08, 2009 2:19 am Post subject: Not Helpful |
I understand that people are encouraged or rather expected to conduct a search of the forums for the answer first, but there's no reason to be a jerk about it. Good job being a snarky toolbag. |
Posted: Fri Oct 09, 2009 3:59 am Post subject: |
You're a day late and a buck short Billy Mays. Besides you're dead too.
Why should I have to post multiple answers because the original poster posted in multiple places? |
Posted: Fri Oct 09, 2009 5:01 am Post subject: |
Sham-on.  _________________ You're over there, I'm over here. |
cnfix
ab8ru
Posted: Thu Oct 22, 2009 12:31 pm Post subject: Re: Dell Inspiron 1150 Motherboard Circuit Layout |
Anonymous wrote: |
Mind if I ask what kind of solder you are using
I know from experience that there is some really poor cheap solder that does a poor job, and definitely do not use acid core solder it will eat away at your repair job, I will reccomend that you use a rosin core and one company makes a very good 5 core solder.
Also invest in some flux paste . I know a supplier that is retail and I never had any trouble with theirs, but a Pro company has a Brand called Kester and ther are several suppliers out there.
Also are you using a good quality soldering iron
Ill give you a quick list
Weller
Whal
Ungar
there may be others also check the tip if its not dirty .
BTW for everyone reading this post.. Advice do not attempt to repair a MOBO ( MOther BOard ) they are layered and if you do not have the right equiptment to begin with and its ofter better just to replace the MOBO compleatley (sic) they are layered like a sandwich, and solder does not go where its intended, and will cause problems. _________________ AB8RU Extra Class Ham
Electronics School IT FCC License P3-18-86210
Membership IEEE & ISCET, ARRL Life Member
Acredited Ham V.E.
Want to be a Electronics Engineer ? |
FalconFour
Posted: Sun Nov 22, 2009 10:17 am Post subject: |
Justmanuals wrote: |
Perhaps, then, you should have flagged this topic for deletion to begin with. It would appear that the person whom you're responding to actually found this topic via searching, and at the time, only found a dead-end at "I answered this in the other topic" - with no link to the other topic. There would be no way to look for "the other topic" if this was the only one that turned up a result.
Just sayin' - if you're referring to "the other post", you can probably save a hundred people a good amount of frustration by just posting a link to the other topic instead of filling that link space with how annoyed you are with duplicate posts.  |
