panasonic sa-vk82d disc 5 change error
chiuyeisaac
PostPosted: Thu Apr 01, 2010 6:54 pm    Post subject: panasonic sa-vk82d disc 5 change error Reply with quote
my panasonic sa-vk82d displays (flashing ) `change` with disc `5` flashing as well. nothing else works and it will go into standby after a while. please help
PostPosted: Thu Apr 01, 2010 11:21 pm    Post subject: Reply with quote
Disassemble - Clean and lube MODE switch - Reassemble (Timing mechanisms "correctly"). Very Happy
_________________
chiuyeisaac
PostPosted: Fri Apr 09, 2010 11:53 am    Post subject: panasonic SA-VK82d Disc `5` flashing `Change` Reply with quote
Thanks so much.
I re-assembled the mechanism twice following instructions of CR16 dis-assembly and assembly but to no avail, any other suggestions?
Thanks in advance.
PostPosted: Sat Apr 10, 2010 12:21 am    Post subject: Reply with quote
Did you clean and lubricate the mechanism mode switch so that the electronics will have an idea what position the mechanism is in? Shocked
_________________
razirafi
PostPosted: Mon Feb 14, 2011 7:56 am    Post subject: Panasonic SA-VK82D Reply with quote
Hi, I have the same problem. I cleaned out the mode switches and lubed them. I took out all five trays and cleaned the mechanisms. I re-assembled it back and now I get different positions of the trays when the unit enters error mode. I can work out the mechanical timing of the mechanism in due time but to save precious time, does someone have a procedure for setting the mechanical timing on this?
PostPosted: Mon Feb 14, 2011 9:39 am    Post subject: Reply with quote
pm me with your email address and i will send you the assembly instructions
PostPosted: Mon Feb 14, 2011 3:12 pm    Post subject: Reply with quote
http://elektrotanya.com/panasonic_sa-vk82dgcp.pdf/download.html
_________________
razirafi
PostPosted: Tue Feb 15, 2011 12:18 am    Post subject: Reply with quote
I am not allowed to send PMs yet as I still need 20 posts to be able to do so but thanks for the offer to send me the assembly instructions.
jts1957,
Thanks for the link. I was able to download it and will now start with the correct assembly procedure.
