Joe90sDad
Posted: Tue Feb 21, 2006 4:45 am Post subject: Bosch Fridge Freezer Schematic/ Repair Manual?? |
Does anyone have or can they re-direct me to a Bosch repair manual for a KGU3200GB fridge freezer or similar model or just a schematic for the main PCB?
My one seems to have overheated in certain areas and I suspect one or more of the diodes but can't read the value off one of them.
Thanks!  |
Posted: Tue Jul 04, 2006 7:09 pm Post subject: |
I'm repairing a similar model, and I'm finding the foult (triac? or zener, capacitors?).
Have you got any idea?
Grazie,
Andrea |
Posted: Sat Nov 19, 2011 12:35 am Post subject: Bosch Fridge/Freezer Not Working |
I had this problem with my Bosch Fridge/Freezer. The compressor was receiving half-wave rectified a.c from the BT139 600 Triac on the control board (Typ 9 708 050). This was causing it to make a terrible noise before shutting down as the temperature overload cut in.
I changed the 16v Zener diode at the edge of the board, (its number is obscured but it is next to the 27v Zener D14). I also changed C8 47uF 25v and C3 100uF 63v.
The other Zener is also 27v.
I replaced the 16v Zener with a much higher current equivalent as this is the second of these boards that has failed in this fridge/freezer.
Incidentally to check that it is the PCB and not the compressor that is at fault you can apply mains directly to the compressor by removing the plug on the laft (as seen from thr ear) cabinet wall and shorting the brown to the black leads - easy as it is a female connector. If the compressor is OK it will run smoothly and the fridge/freezer will cool down. |
Posted: Sun Dec 11, 2011 12:09 pm Post subject: kgu34123gb/01 BOSCH FRIDGE FREEZER |
PLEASE could somebody tell me how to set the fridge temperature on this model. It was showing 5 on the digital reading but i feel this is not cold enough, is 5 the coldest? I phone Bosch as have no manual and the lady i spoke to didn't seem certain that 1 was warmest and 5 was coldest!
Please help  |
plexus914
Posted: Sun Oct 28, 2012 5:15 pm Post subject: Re: Bosch Fridge/Freezer Not Working |
[quote="Anonymous"]I had this problem with my Bosch Fridge/Freezer. The compressor was receiving half-wave rectified a.c from the BT139 600 Triac on the control board (Typ 9 708 050). This was causing it to make a terrible noise before shutting down as the temperature overload cut in.
Incidentally to check that it is the PCB and not the compressor that is at fault you can apply mains directly to the compressor by removing the plug on the laft (as seen from thr ear) cabinet wall and shorting the brown to the black leads - easy as it is a female connector. If the compressor is OK it will run smoothly and the fridge/freezer will cool down.[/quote]
Compressor shutts off after 3 seconds.
It is the same boad as in my Siemens Sikafrost Refrigerator (KG34E02/01) - I am going to use your repair instruction...(I will replace all diodes and capacitors you mentioned).....and I will let you know when i was successful.....=;o)... |
VESTEL • 32PHS5302 32PHT5302 43PFS5302 43PFT5302 • Olevia LT32HV LT37HVE [SM] Olevia • CDM-7834R,7837R ALPINE • PRS-X340 Pioneer • hfe pioneer centrex kh-818 858 8811 8855 • B100 056 CANON • mch6603 Sanyo • 70299-WW-1 MAKITA • toshiba rd-xv49dtkf sm TOSHIBA •
