electronics, repairs, service manuals and datasheets discussion community for the repairs professionals and technicians
FAQSearchMembersGroupsRegisterProfilePM'sLogin/Out
denon udm3
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9
Post new topic   Reply to topic    Electronic equipment repair and service manual search discussion Forum Index -> Equipment Repairs
View previous topic :: View next topic
Author Message
jts1957
PostPosted: Tue Oct 20, 2015 11:29 am    Post subject: Reply with quote
srestaino wrote:
Top of CD caddy with previous circuit board removed
If anyone can give me a pointer at least, that would be fantastic. It would be such a shame to have to throw out this stereo unit just because of what seems to be a small defect.
PS Apologies for the 'test post'. I don't seem to be able to remove it. Admins, feel free to do so.
Well, first you should have started your own thread. Second you say the mechanism works fine if the tray is opened / closed and disc installed manually.
In this picture, there are two boards. The one with two motors has a 'limit switch' that can become tarnished. Unsolder motor terminals, remove board and turn board upside down, pull clear plastic cover / insulator off leaf switch, burnish contacts and reassemble.
Second, just to the right there is a second board with a single motor and two 'tact' switches. The motor shaft probably has a worn belt and/or one or both 'tact' switches are failing to make reliable contact. Usually you can hear motor spinning trying to pull the tray fully closed or push it fully open as the worn belt 'slips.' Unsolder two joints on motor, remove the single screw and release the black plastic clip below it to remove board. Belt should be accessible from the top with the tray, I believe in any position other than fully closed.
_________________
You're over there, I'm over here.
Back to top
View user's profile Send private message
fredleon
PostPosted: Tue Oct 20, 2015 10:11 pm    Post subject: different model Reply with quote
Hi,
as well as being a different model it sounds like a different problem as well. Possibly fuse related but on your pics I can't see anything with the same naming conventions as on the UDM3 (where the fuses seem to all begin with PR)
Sorry I can't be of help, I'm no electronics whizz and I just followed fatz2000's excellent post to the letter.
Hope you get a fix.
fredleon
Back to top
guestbonsaibuddy
Guest
PostPosted: Wed Jan 04, 2017 3:16 am    Post subject: ud-m3 reapir Reply with quote
i have done the same repair to my ud-m3 as in listings. works perfect. no need to drill holes for wires as is gap just above the circuit board to the side then used pin nose pliers to grab the wires.
Back to top
icybee
PostPosted: Sun May 07, 2017 4:56 pm    Post subject: Denon udm3 Reply with quote
Message for newcoppiceman
Hi found a post on the forum re cd tray failure - I have my daughters unit which has failed - I suspected the grandkids had stuffed something in and took cover off but nothing obvious - I am not very technically capable - would you be able to look at unit and see if it's repairable - will pay of course - I live in wokingham and daughter is in Epsom so we pass by Woking regularly - especially when the M3 is shut!! Hope you can help - cheers - Ian
Back to top
icybee
PostPosted: Sun May 07, 2017 4:58 pm    Post subject: Denon udm3 Reply with quote
Back to top
rothana
PostPosted: Sun Jul 09, 2017 12:39 am    Post subject: Reply with quote
DENON UMD-30. A very clean and smooth sounding unit. The design is classic and display is adequately bright. If you're limited for space and budget, this is the ...
goldenslot
สูตรบาคาร่า
Back to top
View user's profile Send private message Send e-mail
fatz2000
PostPosted: Thu Jul 05, 2018 3:03 pm    Post subject: Repost with images Reply with quote
I thought my denon UD-M3 was ready for the bin (no cd eject problem), but I emailed some chap who sold one on ebay with this fault - he said it was a fuse somewhere too.
Took my unit apart, and I mean apart. All the boards out etc. The previous post regarding the PR003 is spot on. These are fusable links, they look like brown resistors with only a number. In this case 500 (ma).
Mine was open circuit as expected.
The location of PR003 is on the underside of the main board. As you dont have to remove the failed component - you can solder a new fuse on the topside.
CHECK YOURS IS OPEN CIRCUIT FIRST. I did this whilst the component was on board since it should be a short circuit.
Heres are piccys of my fuse in place. You can see the PR003 markings on the top side of the board.
http://www.ukholeinone.com/closeup-denon-udm3.jpg
http://www.ukholeinone.com/overview-denon-udm3.jpg
I've used a fast blow 500 milli-amp fuse (40 pence each), and the unit is working fine now.
Obviously do all of this at your own risk!!
Back to top
albertjenkins
PostPosted: Wed Dec 12, 2018 2:59 am    Post subject: Reply with quote
Hi, My Denon UD-M3 is not able to play commercial music CDs. It skips, repeats a section continuously, freezes, etc. In desperation, I've tried a high-quality cleaner to no avail. Anyone with instructions/suggestions on how to replace/repair the CD drive? Any ideas? Thanks.
_________________
five nights at freddy's demo online
Back to top
Guest
PostPosted: Mon Apr 15, 2019 2:14 pm    Post subject: Reply with quote
I have been looking for this information for a long time, I was very surprised when I found it here.
Back to top
FABIANAN
PostPosted: Thu May 16, 2019 9:12 am    Post subject: Reply with quote
Discovered this string while in the meantime inspecting for a fix for my Denon. Thought I'd give it a go despite having NO understanding of electrics or verifying. Picked to place an in-line merge holder thusly expected to change the gathering plate undercarriage irrelevantly to suit it.
Back to top
Display posts from previous:
Post new topic   Reply to topic    Electronic equipment repair and service manual search discussion Forum Index -> Equipment Repairs All times are GMT
Page 9 of 9
Jump to:
You can post new topics in this forum
You can reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Електроника София - Service Manuals Free Download - Prikachi - Service Diagrams
Free TV Schematics Download - HARDW.net - Pinout Master - Jabse Search - Jabse.InK  - Pulsator
Connector Pinout Forum - Новини - SnimkiOt.com - безплатен DNS - Whois разузнаване - Poblizo.com : пътешествия
