Posted: Mon Apr 30, 2007 4:28 pm Post subject: Technics SH-GE90 Equalizer fault - help! |
Hello all!
I have recently bought a technics SH-GE90 equalizer and it has a fault: flashing screen and loss of memory when power cycled off and on.
Anyone know how to fix this? Anyone know where I can get a circuit diagram for this?
Thanks in advance.... |
Homie Guest
Posted: Wed May 26, 2010 11:17 pm Post subject: |
Hello everybody,
I had this problem on my GE90 and I found, that the electrolytic condenser C715 (100uF/35V) in power supply (its on the mainboard near the input from transformator) was bad. It should stabilize a negative voltage for display and when it doesn't, 50Hz from mains supply interferers with refresh frequency for display and this is why it flashes. It was my solution, I hope that it helps somebody
good luck |
Zsolio Guest
Posted: Tue Sep 13, 2011 5:08 am Post subject: SH-GE90 display fault |
I had the same problem, and then replacing the elco C715 solved the bug. It took 15 mins, and $0,1. |
[email protected] Guest
Posted: Sun Jan 07, 2018 12:33 pm Post subject: Re: SH-GE90 display fault |
Zsolio wrote: | I had the same problem, and then replacing the elco C715 solved the bug. It took 15 mins, and $0,1. |
Hi all,
I also had to replace C715 by a new one.
Problem solved!
Thanks! |
bblakie1 Guest
Posted: Wed Jun 20, 2018 7:45 am Post subject: |
Where would i get a condenser C715? I have the same problem |
Posted: Wed Jun 20, 2018 4:53 pm Post subject: |
No ebay near you?
Digikey, Mouser, Fry's (in USA) _________________ You're over there, I'm over here. |
SA-HT500E PANASONIC • 10th Generation PlasmaTV Panel Replaceme • Panel CHIMEI INNOLUX V315HH6-LS1 2 [DS] • V110CZ Toshiba • . lfm2. oscillator. circuit diagram Farn • 2sc3456 Inchange Semiconductor • 599742513HU AEG • lg cm9960 LG • hmc40tpem s6 panasonic • CF75, CF76 siemens •
