How to Fix a Broken Laptop Battery
lorryone
PostPosted: Wed Dec 08, 2010 8:57 am    Post subject: How to Fix a Broken Laptop Battery Reply with quote
Your laptop battery will eventually weaken over time. A battery that previously lasted two hours on every charge a few years ago now only lasts for 30 minutes. This can be frustrating, especially if you use your laptop frequently and you count on it to be portable. You can fix a broken or worn out laptop battery by simply replacing it with a new one. Doing so will require some minor disassembly of your laptop. Note that opening your laptop may void the manufacturer's warranty. Check your warranty before proceeding with this repair procedure.
Things You'll Need: Screwdriver, Hobby knife or single-edge razor blade, New batteries
1. Allow your laptop battery to fully drain. Then, remove the battery from the laptop, by turning the unit face down and locating the battery compartment. You might need to remove one or more screws from the compartment cover or slide open a latch, depending on the model of your laptop.
2. Slide the battery out of its compartment. The battery pack may be a single unit or may contain contain about six individual batteries in a case, depending on the make and model of your laptop.
3. Remove the individual batteries from the plastic case, if your laptop has a case with multiple batteries; if not, go on to the next step. Use a hobby knife or single-edge razor blade to open the plastic wrapped around the case, if there is any, in order to remove the individual batteries. Replace the old batteries with fresh ones.
4. Insert a new battery pack into the battery compartment of your laptop. Refasten the screws or slide the latch to the closed position to secure the battery compartment door.
5. Plug your laptop in to the AC current and allow the battery to fully charge before using the computer again.
View user's profile Send private message Visit poster's website MSN Messenger
another DIY aficionado
PostPosted: Fri Apr 29, 2016 2:53 am    Post subject: caution wit this procedure Reply with quote
If your battery is still holding 30min, do not replace it, yet.
If you can't find an exactly same original battery, it is very likely that other brands of batteries will just last 30 min, "new" or after few weeks of your purchase.
Many times the cells are still good, but a chip (eprom) in the battery circuits reports that the battery can't hold the charge. That is "programmed obsolescence"
I found one page on the web telling how to reprogram the eprom if yours have the same chip number.
Other advice was that, if you change the cells, you should never leave withtout power the circuit, to prevent it to erase and block. You can use a pair of alligators connected to another battery or any other power source of the same rate (often 10.3v).
I could not try that procedure and I changing the cells on a not original battery case did not work for me.
It would be great if someone could manufacture battery cases for replaceable cells where the circuit just prevents that the cells does not overcharge. Other status information could be sent through an USB connector.
If I were an electronics expert I would design something like that.
That problem with the battery seems to be the rule in all computer brands.
Why should I replace my computer, just because I can not find a good quality replacement battery?
I know how to configure my computer, should I have to buy a new one and invest time to learn about it's drivers and peculiarities, just because I can't buy a good battery for it?
Computers should be replaced when they become obsolete for the job that one does on it, or due to failures due to bad maintenance, misuse or accidental dropping by their owners. Circuits are too reliable today, although the new lead free chips have fragile welding spots more sensible to overheating.
JenniferT
PostPosted: Tue Jan 23, 2018 6:21 am    Post subject: Re: caution wit this procedure Reply with quote
Thanks fixed
_________________
ethernet cable
johnson83
PostPosted: Fri Feb 02, 2018 1:47 am    Post subject: Re: caution wit this procedure Reply with quote
Thanks fixed
Thank you Mr. Green
avasmith
PostPosted: Sat Jul 07, 2018 12:20 pm    Post subject: MBA Essay Writing Service Reply with quote
Step 1: Take your battery out and place it in a sealed Ziploc or plastic bag.
Step 2: Go ahead and put the bag into your freezer and leave it there for about 12 hours. ...
Step 3: Once you take it out, remove the plastic bag and let the battery warm up until it reaches room temperature.
I am working for MBA Essay Writing Service Provider in Australia.
_________________
I am an academic writer work for law essay help company in Australia.
View user's profile Send private message Visit poster's website AIM Address
kristenwarne
PostPosted: Sat Jul 14, 2018 11:15 am    Post subject: Scholarship essay writing service Reply with quote
Students Assignment Help offers the best scholarship essay writing service for all college students around the world. Our expert assignment writers will assist you with writing assignments at the reasonable price.
