jashan
Posted: Mon Feb 04, 2019 12:47 pm Post subject: Help needed with old CD unit for MCC Smart |
I've bought an old Grundig CD unit at a junkyard, which I will use as substitute for the casette unit.
The issue is that the unit comes without the code, and the sticker which should be in the side is not there (perhaps it got unsticked due to the time)
Anyway, there is a number engraved in the metal:
MC341641505105
And there is a small sticker with a bar code at the back of the radio, with the following info:
"C1 Smart CD"
01300238241008
Don't know if I've made a mistake buying this unit, but I did not realize that the main sticker was missing until I arrived home.
Thank you for your help!
Best Regards |
jashan
Posted: Wed Feb 06, 2019 12:58 pm Post subject: |
Hi!
Any help would be welcomed, I would like to install it in the car.
Thank you very much in advance
Cheers |
tmcu
Posted: Wed Feb 06, 2019 3:40 pm Post subject: |
| jashan wrote: |
Hi!
Cheers |
You should be able to get the original code from the MC............ serial number
but I don't know any source of free codes . |
jashan
Posted: Wed Feb 06, 2019 6:05 pm Post subject: |
Hi tmcu!
So the number which is engraved in the radio is not enough to find the code for this radio?
If so, what a pity, I've thrown my money... they will not refund me...
I have the VIN number of the car (I took a photo), but I doubt I will be able to find anything...
May I find anything inside of the radio, or do you think that there will not be there either?
Thank you |
tmcu
Posted: Thu Feb 07, 2019 9:39 am Post subject: |
| jashan wrote: |
Hi tmcu!
Thank you |
Sorry if I didn't explain well , yes you should be able to get the code from the engraved number and the vin number from the main dealer or find a local decoding (car audio shop etc. ) service who can recode it. |
jashan
Posted: Thu Feb 07, 2019 11:16 am Post subject: |
| tmcu wrote: |
| jashan wrote: |
Hi tmcu!
Thank you |
So the issue is thatt you can not help me with this because is not as straightforward as it was with other old radios in the past, is that right? |
tmcu
Posted: Thu Feb 07, 2019 1:01 pm Post subject: |
| jashan wrote: |
| tmcu wrote: |
| jashan wrote: |
Hi tmcu!
Thank you |
There are quite some makes of radio that we can help with and quite some that we can't , some radio codes can be calculated from the serial number ,
some are just random issued when new and recorded in a database , most
grundig are the second type ! |
jashan
Posted: Fri Feb 22, 2019 9:04 am Post subject: |
| tmcu wrote: |
| jashan wrote: |
| tmcu wrote: |
| jashan wrote: |
Hi tmcu!
Thank you |
Ok, understood, thank you very much tmcu
And couldn't you try to give me a code? Sometimes it works...
Kind Regards |
jashan
Posted: Wed Apr 10, 2019 12:02 pm Post subject: |
Hi all,
As it's not easy to find the code, just wanted to know if anyone knows any decoding service for this specific unit.
Thanks
Regards |
tmcu
