Datasheet for CCE7101 IC used on electronic tootbrush Braun
Post new topic   Reply to topic    Electronic equipment repair and service manual search discussion Forum Index -> Service manuals & datasheets
PostPosted: Sun Oct 25, 2015 9:12 am    Post subject: Datasheet for CCE7101 IC used on electronic tootbrush Braun Reply with quote
Hello all,
I am lookin for the data sheet of a 8 pin IC SMT used on an electric toothbrush from Braun Oral B Type 3709. I found a link saying the mnufacturer is Lumino, I think a chinese one, but no data sheet yet available. It simply monitors the pushbutton to switch on the Mosfet driving the motor, and probably it also control the battery charge, but I need some more information, if possible.
Thanks in advance for your help!
PostPosted: Sun Oct 25, 2015 8:18 pm    Post subject: Reply with quote
Typical wisdom would be; Why fix an electric tooth brush?
However, it is beside the point when posting for information.
While I do not have the data, it is more than likely a copycat of a "7101" number originally made by a legit manufacturer. Could be anything from a regulator to an optocoupler switch to... Search for "7101" and compare.
I run across this often and as a rule of thumb especially when there is no logo of any kind, it is a copycat and due to lower costs not only it will make it in to consumer products, there will be no specific datasheet.---(logos are copied too)
May have better luck drawing the actual diagram if it is worth your time.
PostPosted: Tue Oct 27, 2015 3:52 pm    Post subject: Reply with quote
Thanks for your suggestion anyway. I am always trying to fix any broken device because I like it.....The circuit is quite simple and the IC is probably working well. I was looking for the data sheet just to pinpoint the possible failure in the PCB in an easier way. I 'll keep investigating then!!! Bye
Guest110
PostPosted: Wed Mar 14, 2018 11:58 am    Post subject: IC Reply with quote
Any look finding the IC?
Kind regards,
Me_user2827
PostPosted: Thu Sep 10, 2020 12:31 pm    Post subject: Reply with quote
Maybe, your IC is still ok?
After i replaced the Battery, my electric toothbrush seems dead.
I was sure the Battery is full.
I got it working again by putting it short on charging station.
Smile
My Device: electric toothbrush from Braun Oral B Type 3709
Post new topic   Reply to topic    Electronic equipment repair and service manual search discussion Forum Index -> Service manuals & datasheets All times are GMT
