Jarek
Posted: Fri Oct 20, 2006 5:30 pm Post subject: Convergence problem in 1080i ONLY - Panasonic RPTV |
I have an older Panny rptv PT47wx53. One day the convergence on the hd 1080i channels broke, basically all four sides of the picture are bent "in" towards the middle and the three gun colours are way off.
Me and a friend replaced the convergence IC's, STK392-110 and inspected, tested and resoldered the IC resistors. The board itself looks ok too. There was no change once we replaced the board. The 1080i picture is still bad, the 480i and 480p are fine.
Any suggestions on what else might have broken and how we can test and replace it?
Thank you for any suggestions.
Jarek |
Jarek
Posted: Tue Oct 24, 2006 3:25 am Post subject: |
Upski. |
Posted: Sat Oct 28, 2006 10:53 pm Post subject: |
Did you go into the service menu and adjust the convergence in the 1080i mode? |
Jarek
Posted: Sun Oct 29, 2006 12:31 am Post subject: |
Yes, trust me regular adjustment is not the problem, the guns/convergence is really off, the bottom right crosshair cannot be overlapped. |
Posted: Sun Oct 29, 2006 9:19 pm Post subject: |
The DCU/convergence generator stores the information. If 480 is good and 1080 is bad, I would suspect a bad dcu. |
Jarek
Posted: Mon Oct 30, 2006 5:16 pm Post subject: |
Thanks, I'll try to test/change that and see what happens. |
Jarek
Posted: Mon Oct 30, 2006 5:26 pm Post subject: |
Sorry, I can't edit my previous post.
Is the DCU genertor a stand alone part or is it a chip on one of the boards? I have the service manual for the TV but it's missing the schematics and nowhere in the manual does it mention the DCU.
Thank you. |
Posted: Wed Nov 01, 2006 1:09 am Post subject: |
Should be on the signal board as a stand up. |
