View previous topic :: View next topic |
Author |
Message |
Igor
Posted: Mon Nov 13, 2006 2:39 pm Post subject: Sony TV Model KV-32Ws2V |
The fault is as follows:on switch-on the degauss circuit operates but there is no sound or vision, also the standby lamp flashes.Line output transistor has been checked (diode tester) and seems to be good. Any ideas folks?
many thanks |
Back to top |
Frank Guest
Posted: Tue Nov 14, 2006 12:56 am Post subject: Sony |
How many flashs? |
Back to top |
Guest
Posted: Tue Nov 14, 2006 3:36 pm Post subject: |
Thanks for the reply...I'm told the flash rate is about 5 per second |
Back to top |
Guest
Posted: Tue Nov 14, 2006 4:10 pm Post subject: |
on this model i would check for dry solder joints on verticle output ic IC500 and dry joints in general all over especialy around the regulator IC's ... sometimes IC500 can go S/C also ....
but however on this model you may also get a corrupted or faulty EEPROM causing this too which is usualy due to a faulty CRT flashing over, in which case i wouldn't bother replacing the EEPROM as it will usualy fail again a while later the next time the CRT flashes over ...... |
Back to top |
You can post new topics in this forum You can reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
eServiceInfo on FB -
Service Manuals Free Download -
Service Diagrams
Free TV Schematics Download -
HARDW.net -
Pinout Master -
Jabse Service Manual Search -
Jabse.InK -
onTap.bg
SnimkiOt.com -
Poblizo.com : пътешествия
Latest Service Manuals :
ech8663r Sanyo • 21CN4462 Philips • AA-8000 Akai • CTS740S Pioneer • • fore NOKIA • PRESARIO 1500 SERIES SM Compaq-HP • BN41-00414A Samsung • 22RH591 SB 1355305890 Philips • bdt81f 83f 85f 87f Inchange Semiconducto •
