teroma25
Joined: 24 Oct 2006 Posts: 5 Location: Ontario, Canada
Posted: Tue Oct 24, 2006 3:40 am Post subject: rca projection problems |
I just bought a RCA P46151WK projection TV.
When I got it home, I plugged it in and turned it on. It worked for approx. 5 minutes then made 3 snap or pop sounds then died. Now there is nothing, no power, nothing. If you listen at the back when you plug it in, you can hear about 10 or so, very faint clicking sounds then nothing. Any help is greatly appreciated here! |
Posted: Sat Oct 28, 2006 10:58 pm Post subject: |
Look on the back of the set and tell us what the ctc # is. I.E. ctc169.... |
Posted: Tue Oct 31, 2006 10:32 pm Post subject: |
Sorry it has the ctc169pt chassis.
I pulled the HV line off the splitter, didn't make any difference cuz there is no voltage on this line at all. This tells me I need a new flyback, correct?
Also when I test T4101 (reg b+)I get 18vdc, T4007 (raw b+)I get 170vdc and when I ohm the HOT I get 1.4ohms. 1.4ohms no matter how I check it, c-e, b-e, b-c, etc..
Suggestions??? |
teroma25
Posted: Tue Oct 31, 2006 10:34 pm Post subject: |
The guest reply above is me, I forgot to log in. |
Posted: Wed Nov 01, 2006 1:07 am Post subject: |
1.4 means shorted. I'd try a flyback and hot. |
teroma25
Posted: Tue Dec 05, 2006 12:30 am Post subject: |
I haven't had a chance to do anything with the TV till now. Anybody ever order parts from electronix.com? How are they? Comments good or bad? |
teroma25
Posted: Thu Dec 07, 2006 10:17 pm Post subject: |
I sent mate electronics an email telling them what I want and how much for the order. I've got no reply! Do they ship to Canada, do they use UPS or USPS or ??? Anybody know? Not getting a reply usually tells me something about the company! |
Frank Guest
Posted: Fri Dec 08, 2006 12:49 am Post subject: |
Elextronic is allright i allways order from there |
Frank Guest
Posted: Fri Dec 08, 2006 1:14 am Post subject: |
I mean Electronix.com. did you check u4101,r4003,q4101,t4102,cr4101,r4149,q4601,should have 140v at c of hot,alsor4113. |
