Posted: Wed Jan 03, 2007 9:51 pm Post subject: Vertical sync |
I have a Mitsubishi VS-5007R Projection TV, and the screen rolls to the top.....It stopped after about an hour, at first, but now it takes about 4 hours to stop rolling.....any help would be greatly appreciated.....Thanks.. |
Posted: Wed Jan 03, 2007 10:44 pm Post subject: |
Replace C2046 & C2a04 on signal board. |
Posted: Wed Jan 03, 2007 10:47 pm Post subject: |
Thank you for the quick reply |
Posted: Wed Jan 03, 2007 10:50 pm Post subject: |
C2046 47uf @50 V and C2A04 10uf @50v. This should stop your rolling. Let me know. |
Posted: Thu Jan 04, 2007 12:11 am Post subject: |
Minnie,
Any chance you know the approximate locations?
I can't find C2046 or C2A04 on the Signal Board... |
Posted: Thu Jan 04, 2007 12:35 am Post subject: |
C2046 is near a bank of silver colored inductors and C2A04 is near the center of the signal board by a 2-pin connector AY. |
ChrisH Guest
Posted: Thu Mar 01, 2007 3:17 am Post subject: |
Same model Tv VS-5007R is doing the same problem as above, the C2A04 resistor has been changed and the C2046 will be changed tommorow when radio shack opens, the question is:
these resistors dont look inflated or damaged in any way, does that mean they are dead or broken? Also C2A04 was changed and the TV turned on as a test and the V-Hold is still not locked down. |
Posted: Thu Mar 01, 2007 10:50 pm Post subject: |
There capacitors, if you have an esr meter you can check them to see if there dry. |
ChrisH Guest
Posted: Fri Mar 02, 2007 12:10 am Post subject: |
looks like Radio shack doesnt carry 47u 50v, Il try ebay. I will ask my friend if he's got that esr metter |
