kolevbg
Joined: 14 Mar 2008 Posts: 5 Location: Coppell,TX, USA
Posted: Tue Jun 11, 2013 1:29 pm Post subject: Sanyp DP42849 shutting off problem |
More often than not the source of problems in Sanyo DP series is the main board, not the power board.
We've servied at least 100 of those and I am yet to see a single power board being bad.
See here for more:
http://www.coppelltvrepair.com/search?Q=dp42849&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
One thing you can do to narrow that down relatively quickly is try to turn the TV on 4 times in a row after it shuts off.
If the shutdown is caused by the main board then it will lock itself out after the 3rd attempt and you won't be able to start it up 4th time until you disconnect AC power for a while (or power to the main board, of course).
When such a problem is present it won't help looking for a fuse on the main board. At least I've never seen one gone bad. _________________ Bobby
Coppell TV Repair
http://www.CoppellTVRepair.com |
Gmoney5540 Guest
Posted: Sat Nov 02, 2013 2:56 pm Post subject: |
Same model, same problem. I can turn it on/off more than 4 times stoped after 8 times. When turn tv on green light on relay clicks turns itself of then on and keeps repeating itself. Tried a new power board and inverters still the same. No visible bad caps or chips. Any idea where I can get a NEW main board that is not used? |
22-025 Micronta • gl2400 003-221 mono input 2.1 . Various • HA II Gradiente • Product Specification Samsung • keh-p7900 Pioneer • 82901-90031 81901 81902 Svc Jun83 HP • Pioneer PDP-503PE PDP-503PU [SM] Pioneer • fqpf8n60cf Fairchild Semiconductor • WT [snap-in] SK Series WT [WesTech] • CMC 1418AD Daewoo •
