bocek ilaclama Guest
Posted: Tue Oct 19, 2010 2:14 pm Post subject: bocek ilaclama |
thanx  |
pradap
Posted: Fri Oct 22, 2010 10:06 am Post subject: |
Whilst most audio amplifiers have DC coupled outputs, very few if any will operate at DC since they are usually AC coupled at some stage in the signal path. Thus you should expect significant distortion of square waves at frequencies below about 10 Hz.A simple half or full bridge arrangement from the power supply might be more appropriate and easiest to do (Solid state relay idea of Gatomas). If you decide to go that way, ensure you use good (short and thick) wiring layout and diodes to catch any fly-back emf in the load is inductive
_________________________________ |
Posted: Thu Oct 28, 2010 8:22 am Post subject: |
If you need current feedback to get a correct waveform through an inductive load, please take a look at the designs used in vertical deflection circuitry of TVs and monitors. The datasheet of any vertical output IC from the 80's or 90's will give you a lot of hints. A such design will be much simpler if you don't use a H-bridge topology but instead connect the "cold" end of the load to ground via a measurement shunt.
The drawback of using a single-ended amplifier is that it will need twice the supply voltage of a bridge amplifier, and it will cause more ripple on the supply needing a better regulation or big filter capacitors that can withstand the ripple current. |
szoasis
Posted: Tue Nov 23, 2010 7:03 am Post subject: |
Square waveform involves high frequency components and at such low rate and high frequencies I wonder if a solid state rely would do the trick. |
LM729 • Philips 22GF133 Philips • FWV182 ET-SB-EX-SI 1216890778 Philips • ToshivaVCR Manual V210EG D TOSHIBA • Release Notes (Version 04.00.0006) Infin • Panel CMO N133B6-L02 2 [DS] . Various • dtm5 1 .3jpsm ONKYO • irf9z14 sihf9z14 Vishay • 1987-07 Agilent • SCX3400 / SCX340x Samsung •
