scar
Posted: Tue Sep 01, 2015 6:55 pm Post subject: |
yep checked the solder joints on the main board weeks ago when i first disassembled it and they looked good... so do the joints on the SP switch ass. (see pics). i've noticed that the optimal placement of the Speaker B button is when the button is out (i.e. the B speakers are off) and then pushed in slightly (maybe just 0.5-1mm), well before the B speaker button engages/turns on the B speakers
scar
Posted: Tue Sep 01, 2015 6:57 pm Post subject: |
Posted: Tue Sep 01, 2015 10:12 pm Post subject: |
http://imgur.com/BxrJUTR
You may want to confirm by holding a strong flashlight beam on one side while you look from the other, that with each switch in the OUT position there will be nothing on the inside of the switch at the red dots when you drill. You may want to remove switches from PC board if hard to view. Working the switch while lighted may allow you to see if red dots need relocation. IF all looks well, drill a hole at a red dot (you may only need to drill one on each switch, depending on their construction) the diameter of the extension spray tube that comes with your favorite aerosol chemical contact cleaner (Deoxit, Blue Stuff, Tuner cleaner, etc.). Only drill into the switch the thickness of the plastic wall.
It actually looks like once switches are removed from the PC board AND from metal frame by straightening 4 bent metal tabs, that each could be disassembled. Let's only try that IF chemically cleaning doesn't improve. _________________ You're over there, I'm over here. |
scar
Posted: Thu Sep 03, 2015 5:10 am Post subject: |
thanks again jts! the DeoxIt worked pretty well... i had to apply it a few times and work the buttons a lot to work it in there, but the sound is pretty consistent now! my dad is gonna be stoked! |
Posted: Thu Sep 03, 2015 6:10 am Post subject: |
Just remember, it's a stereo receiver ... NOT a drink coaster.  _________________ You're over there, I'm over here. |
CV120 DUAL • [SMD] CD Series Nichicon • Panel AUO T460HW03 VF 0 [DS] . Various • Phonola 5567A PHONOLA • TravelMate 350 Acer • phonola1b62mdata PHONOLA • Philips 8204 100 13280 [SCH] Magnavox • 900a 1100a 9220a 9420a AB INTERNATIONAL • AU-D33 & D22 Sansui • AGD8800 Teac •
