desperate Guest
Posted: Wed Feb 01, 2006 11:15 am Post subject: Toshiba sd2800 refuses to play |
| Loads, spins a little shows "Loading" then shows "Disk Error" and refuses to play. Worked fine the day before. |
desperate Guest
Posted: Thu Feb 02, 2006 8:58 am Post subject: Toshiba sd2800 refuses to play |
I opened her up and noticed laser wasn't turning on.
I tried to force it to turn on by entering 'zoom,0,3,0,zoom' via the remote but it still doesn't turn on. Any ideas? |
sk8881
Posted: Sun Oct 18, 2009 2:06 am Post subject: Probably too late but I have a work-around, Toshiba SD-2800 |
You may already have given up on this model and bought a new one, however, I have (sort of) a solution to this problem. I have a Toshiba SD-2800 that, over the years, has had limited use and today, when I tried to use it, I received constant "Disk Error" messages on all media, blank and pre-recorded. On other boards I saw a reference to shock-absorber feet on the drive mechanism that collapse over time, causing the drive to bind up. I put in a disk and, as quickly as possible, turned the unit upside down. The disk played normally. In order to eject the disk, I had to turn the unit right side up or else the platter would open and the disk would remain inside the unit.
Clumsy? Yes, however, it worked. I plan to open the case tomorrow and see if there is some way to prop up the drive mechanism to avoid the flip action. Doubt I can get new parts on a unit this old. |
Posted: Sun Oct 18, 2009 3:55 am Post subject: Re: Probably too late but I have a work-around, Toshiba SD-2 |
| sk8881 wrote: |
More than likely it is long gone by now since the posting is over 3 years old. I am familiar with the collapsing shock absorber syndrome that was rather common to the SD9200 series(top of the line at the time). Main problem was the rattling sound &/or causing the disc to scrape against the tray due to collapsed mechanism. Of course Toshiba blamed it on substandard discs and came up with a "new & improved" damper kit as a replacement. Even remember the part number: 79070496
Interesting that you can see a similar situation is SD 2800. I think that it is more than likely a collapse lens rather than the mechanism but if you need to raise it, you could always add washers. |
1MB5-Detailed Specification Aug79 HP • CR 150 Grundig • Audio 2 Braun • Cornford MK50HII CORNFORD • Инструкция DCM-290 DENON • Multichannel Measurements in MIMO 802.11 • 2sd1479 Inchange Semiconductor • 19781206 Notetaker Keyboard xerox • ksa1614 Fairchild Semiconductor • GC30-2024-3 OS MFT and OS MVT TCAM Progr •
