EBYDRE12402
Posted: Thu Feb 02, 2006 2:35 pm Post subject: PIONEER SX-950 RECEIVER HELP.... |
HAS ANYONE FIGURED OUT YET HOW TO FIX THE SPEAKER CUTTING OUT PORTION OF THE PIONEER SX-950?....I BOUGHT THIS MACHINE IN A USED SHOP FOR $10.00....EVERYTHING WORKS BUT THE SPEAKERS CUT OUT....IT PLAYED FINE FOR A FEW MINUTES, THEN CUT-OUT THE SPEAKERS 3 DIFFERENT TIMES, AND NOW WONT COME BACK ON....ANYONE KNOW HOW TO FIX THIS?....THANKS FOR ANY HELP.... _________________ THANKS FOR YOUR HELP,
JOHN. |
Baeteman Guest
Posted: Mon Feb 06, 2006 8:10 am Post subject: |
Hi there,
as to my opinion, you're having a prob. with DC offset in one of
the final stages, causing the protectioncircuit to trip.
When it switches off the speaker, try to measure the voltage
at the common ouput point from each final stage.
The voltage there should be around zero volts.
If not, the fault should be found in that final stage.
Look for "dry" solderingjoints. Cool down the transistors (pre-drivers
drivers, final ones) with "cold-spay", and observe the voltage.
If there is a termal problem with one of them, you see it rightaway.
Unfortunately I have no diagram otherwise I could give you some
more hints about it.
Important: NEVER force the protectionrelay on with speakers connected.
This will deteriorate one of them, including the faultly finalstage !
Good luck and kind regards. |
cobra562 Guest
Posted: Tue Feb 14, 2006 3:41 pm Post subject: Re: PIONEER SX-950 RECEIVER HELP.... |
| EBYDRE12402 wrote: |
HAS ANYONE FIGURED OUT YET HOW TO FIX THE SPEAKER CUTTING OUT PORTION OF THE PIONEER SX-950?....I BOUGHT THIS MACHINE IN A USED SHOP FOR $10.00....EVERYTHING WORKS BUT THE SPEAKERS CUT OUT....IT PLAYED FINE FOR A FEW MINUTES, THEN CUT-OUT THE SPEAKERS 3 DIFFERENT TIMES, AND NOW WONT COME BACK ON....ANYONE KNOW HOW TO FIX THIS?....THANKS FOR ANY HELP.... |
Check for cold solder joints around your Outputs as this is a Problem i have seen with this model.Also try cleaning volume control,as this can do the same. |
Sony 1-878-598-11 [SCH] Sony • NV-VHD1EE Panasonic • 107065 Belinea • B51-8631-00(3-PCB) Kenwood • DVDR3320.part3 Philips • RI-28CZ10RX LG (Goldstar?) • BPC03063 HP • buk455-60a-b 1 Philips • lenovo y510 . Various • fo-1460 Sharp •
