troubleshoot Pioneer SX-2900
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Thu Jul 02, 2015 11:07 pm    Post subject: Reply with quote
Follow the multi conductor wire from the transformer board to the Main board. D701 (Bridge rectifier) is immediately to its left.
_________________
scar
PostPosted: Thu Jul 02, 2015 11:27 pm    Post subject: Reply with quote
whatever, i followed the wire to the left and then down in the schematic and see that the + of C701 connects to the right of R609... when i measured that resistance it started out at almost nothing and climbed slowly up to 6.8k after a couple minutes, seemed like it would have kept climbing but i didn't know if i should keep waiting...
for C702, the + of that connects to ground, and there happens to be a wire that comes up to the top of the PCB just underneath the -, so when i measured that resistance it was similar to C701... started out low then climbed up to about 7k when i stopped measuring...
and as i mentioned for C706 it topped off around 12.5 kohms, that was actually C704 i measured Smile
and C706 similar to C701,C702.... slowly goes up past 6k until i take off the probes
scar
PostPosted: Thu Jul 02, 2015 11:38 pm    Post subject: Reply with quote
ah you were talking about this part?
it's the only part that's not freaking labelled! Mad
PostPosted: Thu Jul 02, 2015 11:45 pm    Post subject: Reply with quote
NO Shorts.
Can you 'float' the primary of T1 (disconnect pin 1 or pin 4) and install a good fuse and see if it blows when first plugged into Mains? Also does pressing the power button actuate the relay on & pressing power button a second time turn relay off?
_________________
scar
PostPosted: Thu Jul 02, 2015 11:56 pm    Post subject: Reply with quote
i'm not sure how to do that... all the wires are soldered in pretty tight... i guess i could try desoldering pin 1 on the multi-conductor wire where it connects to the Trans Assembly (43)?
scar
PostPosted: Thu Jul 02, 2015 11:59 pm    Post subject: Reply with quote
oh, and yes, when i press the power button it clicks and then when i press it again it also clicks... it clicks everytime i press the power button, and it also clicks when i plug it in...
scar
PostPosted: Fri Jul 03, 2015 12:10 am    Post subject: Reply with quote
ah i think it has a memory of the last power state, so if i shut it off with the power button, then it doesn't click the next time i plug it in. in this case, the fuse doesn't get blown until i press the power button....
PostPosted: Fri Jul 03, 2015 12:12 am    Post subject: Reply with quote
Item 62 has two pins on one side (Primary) and seven on the other (secondary). Unsolder and let float in mid air either of the primary wires.
I'd like you to leave unit in the 'Off' position, and let me know if for your last if it had a good fuse installed, blown fuse or No fuse.
I'm trying to narrow down as far as possible before any major disassembly is done.
_________________
PostPosted: Fri Jul 03, 2015 12:13 am    Post subject: Reply with quote
I take it you have No or sporadic EDIT feature too?
_________________
scar
PostPosted: Fri Jul 03, 2015 12:24 am    Post subject: Reply with quote
yeah sorry... no edit button over here, must not be enabled on this forum.
okay pin 1 on the primary side floating, good fuse installed and plugged into mains. unit is "off" and the fuse is still intact.
Page 2 of 7
