[email protected]
Posted: Wed Aug 14, 2019 6:20 pm Post subject: audio 10 mf2910 |
Please code for audio 10 alpine radio mercedes
serial number is AL291031298180
Thanks in advance |
bogege2
Posted: Thu Aug 15, 2019 3:19 am Post subject: Re: audio 10 mf2910 |
| [email protected] wrote: |
Thanks in advance |
try code 32116 |
[email protected]
Posted: Thu Aug 15, 2019 7:36 am Post subject: |
Dear Sir,
Code 32116 does not work. Can you give other perhaps?
Thanks |
bogege2
Posted: Thu Aug 15, 2019 3:55 pm Post subject: |
Dear Sir,
Thanks |
If the serial number you gave is correct then this is the correct code!
Check it again! See if you enter this code correctly! It is also possible in the past that someone has decoded this radio and changed the original code!
If the display continually shows "WAIT" then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE " With " C " Flashing
Rotate RH Tuning Knob to Select 1st Digit
Press RH Tuning Knob to Enter
Rotate RH Tuning Knob to Select 2nd Digit
Rotate RH Tuning Knob to Select 3rd Digit
Rotate RH Tuning Knob to Select 4th Digit
Rotate RH Tuning Knob to Select 5th Digit
If the correct code number is now shown
Press And Hold RH Tuning Knob To Enter |
