vivo
Posted: Thu Oct 21, 2021 9:10 am Post subject: Fuse size |
| I currently have a 4 channel amp powering my speakers in my car. I am planning on getting a 12" sub and an amp to power it. I have a 4 gauge wire run all the way to the trunk for my current amp. I am going to get a distribution block and run the 4 gauge wire to the block and 8 gauge wire from the block to each amp. My question is how do I go about determining what size fuse to use. I already have a 60amp fuse for the current amp and I'm not sure what size fuse I will need to replace it with. The new amp will most likely need a 60amp fuse as well so do I run a 120 amp fuse or keep my 60 amp fuse. I'm pretty sure I just need to run a single 60 amp fuse but I want to make sure before I start buying stuff. Thanks. |
zaakee2022
Posted: Sat Mar 12, 2022 5:21 am Post subject: Re: Fuse size |
| vivo wrote: |
You should stick with the old fuse as increasing fuse range will hurt you if any short occurs. |
Posted: Fri Nov 11, 2022 1:36 pm Post subject: Re: Fuse size |
| zaakee2022 wrote: |
Yes that is true if it is possible he should wear some kind of gloves which are electric shock proof. |
Posted: Sun Apr 02, 2023 5:12 am Post subject: Re: Fuse size |
| vivo wrote: |
Never seen a 60 amp automotive fuse. The amp might have it, but 20 amps is a standard car fuse. |
525cj,530cj,540cj,550cj,lw800ic,810ic(bl • thunder1 reverb SUPRO • MARCONI 6200B Series GPIB Operating Marc • hfe fm7 service CYRUS • ve onkyo cp-1280f service ONKYO • ixgh20n60-a ixgm20n60-a Ixys • sch1332 Sanyo • Royal 500 ZENITH • Digimax 48 PRESONUS • 22ah572 Philips •
