Posted: Thu Mar 30, 2006 2:18 am Post subject: Sony KV-X2982U |
Similar problems to another post on this site.
When switched on, standby light comes on and stays on, selecting any channel light goes off and horizontal line centre screen shows then flicks back to standby. Also clicking sound as if relay activated. Selecting any other buttons on the remote such as AV channels nothing happens. Prior to it failing occasionaly lines on top 20% of screen showing.
Cure for other post was to resolder IC1501 described as a 7 pin device mounted on a heatsink at the back of the board. However I cannot find any IC with that number, the only 7 pin IC with heatsink is a IC500 and resoldering this made no difference.
Are there any areas I can test to narrow the analysis, sorry but only have multimeter no scope or other test gear, but I did my HNC electronic eng more years ago than I care to remember, so not a complete novice but no Tv servicing practice.
Any help would be appreciated. |
Posted: Thu Mar 30, 2006 4:13 pm Post subject: |
| on this model ic 500 is probably the cause, if resoldering has not cured the problem try replacing it with STV9379. |
Another Guest Guest
Posted: Tue May 30, 2006 4:38 am Post subject: Sony KV-X2982U |
| I've just had the identical problem problem occur with my Sony KV-X2982U. Can you let me know if there were any further developments with this thread? Any help much appreciated. |
Posted: Wed May 31, 2006 4:21 pm Post subject: |
| HAVE YOU TRIED THE ABOVE. COUNT THE NUMBER OF FLASHES IF THE SET SHUTS DOWN AS THAT GIVES AN INDICATION OF THE PROTECTION. |
RobH
Posted: Wed Jan 09, 2008 3:07 pm Post subject: Same problem |
| I had the same problem. Resoldering IC500 cured it. Thanks Gary!! |
22sc5587 . Electronic Components Datashe • AL1717h Acer • eu14a HEATHKIT • PIC16C5X Microchip • 14391700A Program Command Console Ref No • Armada M700 Compaq • lch2a3 NOKIA • TL (2006) [snap-in] CDC05 Series TL [Ji • 28TIBK Nikon • Panel NEC NL10276BC28-05D 0 [DS] . Vario •
