marwan
Joined: 21 Apr 2006 Posts: 2 Location: Sydney, Australia
Posted: Fri Apr 21, 2006 11:15 pm Post subject: philips brilliance 201p monitor |
The brightness & contrast varies depending on what is displayed on screen.
Sometimes the brightness goes so high that the monitor shuts down.
Does anyone know the fault?
Does anyone have a circuit diagram that they can email me?
Thanks. |
Posted: Sat Apr 22, 2006 3:21 am Post subject: |
| It sounds like it is having trouble regulating the voltage. Try testing all of the filter capacitors and checking for broken solder joints. Have you measured the B+? |
marwan
Posted: Sat Apr 22, 2006 9:22 am Post subject: |
| Anonymous wrote: |
Solder joints ok. It's hard to make measurments without a circuit diagram
as it's a complex monitor, I will try, |
Posted: Mon Apr 24, 2006 4:38 pm Post subject: |
Measure the B+, if it is fluctuating the high voltage will also be fluctuating. When the voltage goes up and things get bright you risk destroying many parts.
Actually you would be better off testing all of the electrolytics in the powersupply before you power it up again, especially looking for open circuit ones. Give them a gentle wiggle, sometimes a leg will fall off and they will be loose. Do you have an ESR meter? |
