turner7A8
Posted: Sun Jun 04, 2006 6:44 pm Post subject: Is a Current Regulator Needed... |
I've recently purchased a Magnavox {15" LCD-TV 15MF400T/37} which can operate on 12 volt DC input.
I want to use this TV in my RV - on a Standard 12 volt, Deep Cycle, Vehicle Electrical System - where voltage can vary from 10 - 15 volts depending on the state of discharge or recharge, etc.
Will it be necessary to regulate the current input (to the TV) with a constant current regulator, and/or voltage regulator ??
Or can I just plug it Straight IN ??
Thanks,
turner7A8
PS- The TV came with a 120 V. AC to 12 V., DC, 4.16 AMP converter and there's no documentation regarding vehicle usage and Magnavox Support
says there's no accessory for 12 volt DC to DC operation. |
Posted: Fri Jun 09, 2006 8:06 pm Post subject: |
Maybe you could have a look at the power supply to your tv and figure out how well regulated it is? Please be careful if you try to examine the power supply for your tv. It can contain a LETHAL jolt of energy even if its unplugged!
However I think that I would go for a regulated 12 volt supply. Thats because the consumption is not relatively high and the cost building a supply is not very expensive. And then you get the right voltage all the time.
I don´t think you should use a current regulator since a current regulator tries to vary the voltage to keep the right current. But it would be good to put a short circuit protection to the voltage regulator. The "short circuit" current can be choosen.
Be careful! |
