Genbradley Guest
Posted: Sun Nov 19, 2006 7:34 pm Post subject: KP43T75 - Removing the G board |
Anyone know who to remove the two wires on the transferemer on the left side? One is lager then the other and the have little rubber caps on them. They both plug down into the transfomer and I cant remove them or the board with out taking the wires out.
My gols is no replace the two Semiconductor STK392-150 to correct the Convergence problem.
THank you |
Posted: Sun Nov 19, 2006 10:16 pm Post subject: |
| If it's the flyback your talking about there should be a thick wire and a thinner wire. Scoot the boots back. The thick wire sometimes you can push down and twist the wire and it will pull out. The thin one if you pull hard enough it will come out. If you think you're going to break something, unsolder the flyback to get it out of your way. Sony sells tools to remove the lead. I use freeze spray on the thick one and try and push down and twist. Good luck. |
Posted: Sun Nov 19, 2006 11:32 pm Post subject: |
Yup that sounds like it.
I thought I broke the thin one. Guess not, Sounds like and looks like it pushes back in. Thanks a bunch
| minnie wrote: |
Posted: Mon Nov 20, 2006 12:32 am Post subject: |
| As long as the metal tip is still on the end you should be good to go. |
Genbradley Guest
Posted: Mon Nov 20, 2006 12:33 am Post subject: |
You say push down first... ? I still cant move the big wire... OY..hehe
| Anonymous wrote: |
| minnie wrote: |
GenBradley Guest
Posted: Mon Nov 20, 2006 12:41 am Post subject: |
No end, stranded wire. maybe its gone then
| minnie wrote: |
Posted: Mon Nov 20, 2006 5:41 am Post subject: |
Tooth picks as a wedge and some silicone will do just fine! Wrap it in electrical tape to boot.  |
Posted: Mon Nov 20, 2006 5:46 am Post subject: |
| Big one, small just pushes back in. |
