allanm
Joined: 10 Nov 2006 Posts: 19 Location: kilmarnock UK
Posted: Mon Nov 20, 2006 3:56 pm Post subject: repair hitachi C32WD2TN2 |
| Hitachi tv with no pic or sound. HT is present at 150v. Set appears to try to come on for 2 secs without much variation in the ht voltage. I've checked the usual dry jointed regulator and other components on the same heatsink. I've also disconnected the frame chip and again there's not much change in the voltage - about 28v. I know these sets don't tend to come on when the frame chip is disconnected. |
goblins
Frank Guest
Posted: Wed Nov 22, 2006 12:24 am Post subject: |
| Unit will not turn on. Measuring the B+ on the CPU found it to be only 4 volts on ICA01(54). Checking the B+ on at the output of the 5 volt regulator found the same low voltage on the output as on the input. Tech replace capacitor C814(1000mfd@ 25 volts) This restored normal voltages to the CPU but it still did not turn on. Further checking the CPU "Must Haves" it was discovered the reset was low instead of 5 volts. Capacitor CA72(2200mfd @ 6.3vdc w |
frank Guest
Posted: Wed Nov 22, 2006 12:41 am Post subject: |
| Solder Link lead throughs on signal processor sub board ZK14,16,19 |
payner pro music • M1400 Mackie • SR10119B LG • ctv-2012z, 2102z . Various • TK-2140-Addendum Kenwood • Panasonic TH-50PZ70E panasonic • ch1before Compaq-HP • Daewoo-Partsnic [radial thru-hole] RUH S • 3A1 Tektronix • 17TX220A Philips •
