KE8JC
Posted: Thu Jun 19, 2008 5:09 pm Post subject: Re: hitachi projections |
bithead9 wrote: | These units can be very easy to repair. you need the service manual. see if it is an AP73 or AP74 chassis. If so you can get the manual here at this site. You simply use the LEDs to see what stage is bad. Get your Ohm meter out and check the pico fuses. |
bithead - do you have manuals already? I am helping a friend with his unit, an AP83. There are 4 green LEDs that come on, then go off. They do NOT change to red. The unit is dead otherwise. I can do component replacement if we can identify what needs to be done. I am not very skilled at troubleshooting whole power supply systems, though. If we absolutely must order a manual and it will tell us what to do, I will have him get it. Thanks for any assistance. _________________ Scott, KE8JC |
Posted: Thu Jun 19, 2008 10:48 pm Post subject: Re: hitachi projections |
KE8JC wrote: | bithead9 wrote: | These units can be very easy to repair. you need the service manual. see if it is an AP73 or AP74 chassis. If so you can get the manual here at this site. You simply use the LEDs to see what stage is bad. Get your Ohm meter out and check the pico fuses. |
bithead - do you have manuals already? I am helping a friend with his unit, an AP83. There are 4 green LEDs that come on, then go off. They do NOT change to red. The unit is dead otherwise. I can do component replacement if we can identify what needs to be done. I am not very skilled at troubleshooting whole power supply systems, though. If we absolutely must order a manual and it will tell us what to do, I will have him get it. Thanks for any assistance. |
Whats the model #? |
Scott, KE8JC Guest
Posted: Sun Jun 22, 2008 6:35 pm Post subject: Hitachi 50UX58B |
The model is 50UX58B. I checked one fuse and it was fine. Are there more to check? If so where are they. The chassis is AP83. Thanks. |
Posted: Mon Jun 23, 2008 6:46 pm Post subject: Re: Hitachi 50UX58B |
Scott, KE8JC wrote: | The model is 50UX58B. I checked one fuse and it was fine. Are there more to check? If so where are they. The chassis is AP83. Thanks. |
Did you check c707 and e994? |
Posted: Mon Jun 23, 2008 7:40 pm Post subject: Re: Hitachi 50UX58B |
minnie wrote: | Scott, KE8JC wrote: | The model is 50UX58B. I checked one fuse and it was fine. Are there more to check? If so where are they. The chassis is AP83. Thanks. |
The fuse I checked is in the last line of the tv by a blue something. |
Posted: Mon Jun 23, 2008 8:03 pm Post subject: Re: Hitachi 50UX58B |
Anonymous wrote: | minnie wrote: | Scott, KE8JC wrote: | The model is 50UX58B. I checked one fuse and it was fine. Are there more to check? If so where are they. The chassis is AP83. Thanks. |
What is the # of the fuse? |
Posted: Mon Jun 23, 2008 10:04 pm Post subject: |
The fuse is 237 |
Kenni Guest
Posted: Mon Jun 21, 2010 8:36 pm Post subject: Re: Hitachi 50UX58B |
How can i find the chassis? |
