Posted: Sat Aug 23, 2008 12:07 pm Post subject: |
Replace the STK392-110's. Could be STK392-150's. Resister values:
Resistor Location Value Part #
RK42 3.3 Ω 1 W AT03202S
RK46 1.8 Ω 1 W AT03195S
RK50 3.3 Ω 1 W AT03202S
RK54 1.8 Ω 1 W AT03195S
RK58 3.9 Ω 1 W AT03204S
RK62 2.2 Ω 1 W AT03197S
IK04 & IK05 STK394-160E CZ01341
STK394-160's are the newest replacement. |
Posted: Mon Sep 01, 2008 7:25 pm Post subject: |
minnie wrote: | Replace the STK392-110's. Could be STK392-150's. Resister values:
I really have no clue what those part numbers are representing, could I just take a pic of the board and you tell me which ones to replace?
Are these Radio Shack parts or somewhere else?
Thanks.
Mark |
Posted: Fri Sep 12, 2008 7:59 pm Post subject: |
If you'd register I could send you a pdf file that shows you. |
PIXER
Posted: Sun Sep 21, 2008 1:23 am Post subject: |
minnie wrote: | If you'd register I could send you a pdf file that shows you. |
DONE, AND THANK YOU |
iwannafixit
Posted: Fri Dec 19, 2008 4:41 pm Post subject: hithach 43fdx20b |
I have bad resistors on the dp1x convergence pwb board, does anyone have the value of the resistors for this board next to the ic's.
Thanks. |
aaronjwithrow
Posted: Sun Dec 28, 2008 9:30 pm Post subject: Green Convergance issue on 55pp9401 Board |
I recently picked up a used set from a co-worker. It was working great for about 10 minutes then the Green appears to be bowed down from the top and up from the bottom. the image looks like it is concave.. you cannot adjust the convergence by using the service mode.
We DO know the issue is on the convergence board - if you swap with blue it follows..
so the question.. It has 2 STK-392-110IC/s It is a DP1X convergence pwb. what are the resister values.. there are 2 that are very difficult to read.. |
Posted: Mon Dec 29, 2008 10:11 pm Post subject: Re: Green Convergance issue on 55pp9401 Board |
aaronjwithrow wrote: | I recently picked up a used set from a co-worker. It was working great for about 10 minutes then the Green appears to be bowed down from the top and up from the bottom. the image looks like it is concave.. you cannot adjust the convergence by using the service mode.
Ask justmanuals if he has a schematic. Phillips dropped tech support. |
freezen3535
Posted: Wed Dec 31, 2008 4:21 am Post subject: Convergence philips 55pp9401 |
Hi there Minnie, After reading many of these posts, you seem to be the one to help me the most. I have a philips 55pp9401 with a convergence problem. The Chassis # on back says its a pp15. Where can I get the correct Ics and resistors to make a repair. Thanks in advance for any help you can give. |
awtoys
Posted: Sat Jan 31, 2009 7:11 pm Post subject: |
Thank minnie, ichage the stk. but i not sure the value resistors, one of then reading 42 ohms, other 17 and when verify the other circuit the resistor are very low. _________________ www.awtoys.net |
