joehp
Posted: Sun Feb 18, 2007 9:15 am Post subject: Green layer on my Toshiba 50H72 |
New user here, I hope I'm posting on the right forum.
3 years ago, I bought a Toshiba Theaterview HD [Model no.] 50H72 [Chassis no.] TAC 262, everything was fine until the color scheme changes while I was playing my Wii.
It basically looks like a thin green layer is placed on top of the screen, and everything it displays now has some green-biased color. I'm not a good photographer so I could not take any pictures off the screen, however I used the Paint program to illustrate the problem. The pic I attached shows what the screen displays what it is suppose to be pitch black.
[img]http://www.geocities.com/e5588849/toshiba.bmp[/img]
At first I only get this problem when I'm playing my Nintendo Wii, now the problem exists even when I'm watching tv shows and dvd. If I leave the tv off for a long time (12+ hours) then turn it back on, the problem will go away for 5-10 minutes then it becomes green again.
Has anyone experienced this problem? What is the cause of this problem? Did I forget to turn off the tv and something has exploded inside? Is it related to other components connected to the tv (Wii, dvd, vcr) ?
Thanks
Joe |
cory Guest
Posted: Sun Feb 18, 2007 1:55 pm Post subject: |
| i found on more than a few toshiba tv that if you carefully check the crt neck boards you will probably find a small crack on one of them.make sure you unplug tv first.if you find a crack you will need to place a jumper or two to repair problem. |
Posted: Sun Feb 18, 2007 4:20 pm Post subject: |
| Pic you attached is no good. |
joehp
Posted: Sun Feb 18, 2007 7:27 pm Post subject: |
| minnie wrote: |
it didn't get the msg across? I'll try to take an actual picture then. |
cory Guest
Posted: Sun Feb 18, 2007 11:56 pm Post subject: |
| have you checked the crt neck boards for cracked traces yet.common problem.ive fixed 10 already at least. |
Posted: Mon Feb 19, 2007 2:13 am Post subject: |
| cory wrote: |
Sounds like he's heading towards a convergence issue. |
joehp
Posted: Tue Feb 20, 2007 10:37 am Post subject: |
Cory: I've never opened up a tv in my life, can you tell me what a crt neck board looks like and where could I find it?
Minnie: What is a convergence problem? Can you give me more info on this? |
cory Guest
Posted: Tue Feb 20, 2007 11:57 pm Post subject: |
| i saw the picture minnie,green an retrace.dont think it is screen problem because he never moved it or was inside.anyway if you take the speaker grill or grills off.remove front cover,then you will see 3 picture tubes with small square boards attached to the ends of them.these are the neck pcbs.gently pull them down and off(mifgt have to wiggle a bit).then look on the underside(solder-side),maybe with magnafying glass and look for small crack.very hard to see.then fix crack. |
