trish
Posted: Sun Feb 25, 2007 8:17 pm Post subject: |
So much for the tech, took the board out and checked the chips and he missed out solding about 6 of the pins.
Now all pins solded and fuses checked. they are all fine.
Though I can not find the FD101 or FD102
Would it be worth replacing the red again?
Does anybody by chance know which STK the red one is?
Thanks Trish |
Posted: Sun Feb 25, 2007 9:06 pm Post subject: |
Ness electronics
RSSPMF 3-1/2 3-1/2A 125V PICO MICRO FU $1.88 |
trish
Posted: Sun Feb 25, 2007 9:40 pm Post subject: |
Hi
and thank you. But if I order from the USA, it will probably take about a week or 2 to get here and may be cheaper and easier here in the Uk
After going through every single fuse round the STK's, all are fine. |
trish
Posted: Sun Feb 25, 2007 10:15 pm Post subject: |
found them
thank you
Axial Fuse 3.5A 125V pack of 5, luckily the same place I ordered my STK's so they can add them into the package.
Wish my husband luck (he is the solder of the house) |
Posted: Mon Feb 26, 2007 12:03 am Post subject: |
Now, did you take a multimeter and check them or are you going by the way they look? |
trish
Posted: Mon Feb 26, 2007 7:45 am Post subject: |
We checked them all using a multimeter. |
Posted: Mon Feb 26, 2007 9:56 pm Post subject: |
All resistors around the IC'S? |
trish
Posted: Mon Feb 26, 2007 10:52 pm Post subject: |
Hello
yes. Tomorrow we will check the fuses under the IC's and hopefully find replacements for them, as if they are under the heat sink then these we have not yet been able to check.
So plan for tomorrow is:
Check the fuses under the heatsink, replace and hopefully....
As soon as we have done so, I will put in another update.
Thank you for the help so far. I am now hoping it is one of the pico fuses. |
trish
Posted: Tue Feb 27, 2007 9:20 pm Post subject: |
Hello again
Fuses have been changed, and I was able to adjust all the colours
Whilst in the service menu and adjusting and adjusting the set just went off.
Turned it back on as I thought I hit a button, then I could no longer adjust the blue.
Went off again after about 15 minutes, then I was able to adjust the blue...
Very strange goings on.
Have I connected something wrong?
Or is this set now trying to drive me mad?
Thanks Trish |
trish
Posted: Tue Feb 27, 2007 11:19 pm Post subject: |
OK
No idea what was wrong, ALL IS FINE AND WORKS AGAIN!
The problem was one of the pico fuses.
Now a lot of aligning to do, but have provisionally aligned this evening and apart from a few wonky lines (as I did not use a template or DVD)
Perfect picture!
THANK YOU SOOOO MUCH! |
