PigLib Guest
Posted: Wed May 09, 2007 6:56 pm Post subject: Mitsubishi VS-5004R Green Screen. I could use some guidance |
I have a Mitsubishi Vs-5004R that when powered on the screen is completly green.
I woke up to this problem after the TV had been working perfectly the night before. It was shut off when i went to bed.
After removing the screen i see that only the green projection bulb is coming on. If any of you folks have information (service manual) or experience with this issue your help would be greatly appreciated!
I am aware the this TV is very old (mfg date 1991) and probably not worth putting any money into however i would like to try to repair it as i have experience with electronics and circuit boards, I have just never worked on a TV before.
Thank you in advance for your help! |
piglib Guest
Posted: Wed May 09, 2007 7:57 pm Post subject: |
Just to follow up with some more information...
i have found that when i change inputs to ext-2 i do get all three tubes to come on when you get to the code entry screen (because that input is locked with a code you have to enter) however the normally green lettering (against a blue background) for that code entry screen is washed across the screen almost smeared looking.
As i am sitting here typing the TV just shut off on its own. after being on that ext-2 screen for approx 5 minutes.
I have also checked to make sure that the green tubes coolant has not leaked on to the crt board. as of yet i have found no cold solder joints on any of the three boards (but i just started looking with the green one)
Thanks again in advance... |
PigLib Guest
Posted: Thu May 10, 2007 1:33 am Post subject: |
okay heres where i am at...
I have removed the green crt board and resoldered all solder connections.
Reconnected and same problem
by chance i removed the green crt board with the tv on and when i did the blue and red bulbs came on and work perfectly (no smearing of picture)
needless to say i can watch tv but the whole picture has a magenta hue to it.
Seems to me that the issue is in the green crt somewhere and is related to that tube getting too much voltage and forcing the other two to shut down.
Someone should let me know if im on the right track here.
Thanks Again |
piglib Guest
Posted: Sun May 13, 2007 9:41 pm Post subject: |
| ttt |
Posted: Mon May 14, 2007 11:55 pm Post subject: |
| Rap on the tube with it running and tell me what happens. |
piglib Guest
Posted: Tue May 15, 2007 8:03 pm Post subject: |
| Thanks for the response minnie! Gave the green tube several good raps and nothing happened. What now? |
Posted: Tue May 15, 2007 10:26 pm Post subject: |
| Did you taker the speaker grill off and try to turn down the green screen control? |
piglib Guest
Posted: Wed May 16, 2007 12:36 am Post subject: |
if you are refering to the small dial on the crt board, then yes.
i also adjusted the focus control located on the board that is located on the right wall of the tv.
had no luck with those either
any other ideas? your help is greatly appreciated. |
Posted: Wed May 16, 2007 11:24 pm Post subject: |
| How does the picture look over all? |
piglib Guest
Posted: Wed May 16, 2007 11:42 pm Post subject: |
Well i have been using the tv without the green crt board plugged in so it is working fine but the whole picture has a magenta (pink) hue to it.
with the green tube plugged in the other two tubes shut down making the green completly overpower everything.
