skeletor/parka Guest
Posted: Sat May 12, 2007 2:00 am Post subject: pioneer dvd xvhtd530 flashing timer |
| all start due to a surge the transformers fuse blew out so I use a thin wire to make it work then I enter the sevice mode the display shows protecct error this means that there is something wrong with the amp assy but I already check everything the protecction sistem check for shorts or low or high voltages called abnormability maybe the transformer's out put became corrupted after the surge the transformer is ATS7354 if anyone knows any solution or tip about it or at least the right voltage output thanks for any help |
HP 8568B Operating & Programming Agilent • • j111 j112 j113 cnv Philips • fds8876 Fairchild Semiconductor • 2sa1146 Inchange Semiconductor • 2sd1827 Sanyo • pcbmn2 panasonic • tx p42c2b e l pr42c2 panasonic • Compaq Presario 1200 Series COMPAQ • FM-4 Recital FM-5 Brian FM-14 Card FM-44 •
