none Guest
Posted: Wed Feb 23, 2005 6:52 pm Post subject: Just had my repaired this morning $375 |
It was a simple soldering job.
A little bit of a pain to get to. He did say to put plenty termal-heat compound on the back of the stk392-110. He said the makers rarely put enough and therefore causes a problem.
It took him 20 min.
Just don't turn on the tv with the back off. He warned me that it would blow some component. |
Larry E Guest
Posted: Thu Feb 24, 2005 12:59 am Post subject: Hitachi tv |
Joe, are you saying he charged you $375 to resolder the stk`s??
cause if you are you definitely got hosed this time,
first of all he should have replaced them, reapplying heat sink
compound to old stk`s as a repair after resoldering them is a
bandaid, if the stk`s are tired they will fail in a month or two, make
sure you keep that receipt, you`ll probably have to call him back before too long, Larry E |
joe1715jt
Posted: Thu Feb 24, 2005 1:27 am Post subject: hitachi finally fixed |
The serviceman came out today - and three hours later - the tv was fixed. A burned-out resister (RK46) caused the two ICs to fail. He replaced the ICs with two new ones (STK392-150) - and the resister. He said he used 150 watts instead of the lower 130 because they would tolerate the heat better (or something like that). $120 in parts & $269 in labor. After my first experience, I thought this was worth it. He not only turned the tv on, but he took a part the back, pulled things out, etc... He seemed honest and upfront with costs. When he was done, he cleaned the internal glass, lenses, etc... Picture looks pretty good for an 7-year-old tv. I'm happy. |
Larry E Guest
Posted: Thu Feb 24, 2005 7:17 pm Post subject: |
If your happy were all happy , Larry E |
deniharn Guest
Posted: Tue Nov 07, 2006 12:38 am Post subject: Hitachi 50UX58B PART |
DOES ANYONE KNOW WHAT THE PART NUMBER IS FOR SLOT L710?
I HAVE ALREADY REPLACED C707. L710 IS BAD TOO!
PLEASE HELP WITH PART NUMBER OR AVAILABILITY OR WEBSITE!!
THANKS!!
jd5449
Posted: Sun Nov 12, 2006 2:11 pm Post subject: hitachi part |
denihard the part #is bz00318 it's a linearity coil 50uh-w |
V9079-90001 V9079B TD-SCDMA User 2527s a • 058ats LG • [radial] MIN-13 Series Joemaster • aj-15 HEATHKIT • s a4 t panasonic • Compaq Armada 100S and COMPAQ • cd74hc166 Harris Semiconductor • [bi-polar axial] RMN Series Richey • bsc030n03msg rev1.16 Infineon • RCD 300 PASSAT B6 grundig •
