munawar5555
Joined: 12 Feb 2005 Posts: 1 Location: Karachi, Pakistan
Posted: Sat Feb 12, 2005 8:04 pm Post subject: TV Problem LG with circuit MC-84A |
Hello,
I am trying to repair my personal use TV, its LG made with circuit MC-84A.
Behaviour of TV :
1)When I switch on TV its red light turn on, but TV dont get on, it takes some time about 2 to 5 minutes or more, after some times its screen gets start.
2)When TV gets start its do not accept remote control signal or also its do not work with switches on TV for channel change or for volume, but sometimes it work.
3)Some times when remote work on TV then after few minutes remote stop working and also buttons on TV dont work for channel or volume.
What I have checked:
1)I have checked that remote is 100% OK.
2)I have checked that TV buttons are 100% OK, because they are providing singnal at IC CXP86324.
3)Also voltage on pins of this IC is seems ok with respect to circuit diagram.
4)One thing I have noted that STR-F6654 pin-3 has voltage 311, but on circuit diagram written that it should be 135 volt, other pin voltage of STR-F6654 is OK , but only pin 3 voltage is higer from written of circuit diagram.
5)Also I have resold pins of ICs to avoid any dry connection.
6)Transformer T802 pin7 and pin5 both has same 300 volt, its pin 5 going to STR-F6654 pin 3, does STR is faulty or transformer, or any other problem ?
But my problem is still remain, could any one help me to solve this problem.
Thanks
Munawar _________________ Life is only 15 minutes , then .... |
Posted: Sun Feb 13, 2005 2:56 pm Post subject: |
| Also I have noticed that on FBT Transformer there is not voltages on many pins as mentioned on circuit diagram, plz help me to sort this problem |
[email protected]. Guest
Posted: Wed May 18, 2005 10:48 pm Post subject: LG tv |
Hi,Munawar,
i wander know if you line AC voltage is 127vca or another rating
because i see a bridge,a filter and the 7-5 wind of t802.....there aren´t a doubler or anything sort to get 300vdc, to Drain in pin #3 of IC803
By the way check r 805 pin #2. |
yep Guest
Posted: Sat Jul 09, 2005 1:34 pm Post subject: Re: TV Problem LG with circuit MC-84A |
| i have the same problem with the the lg t.v switching on. I tried to get someone in to fix it but they didn't know how |
yep Guest
Posted: Sat Jul 09, 2005 1:41 pm Post subject: Re: TV Problem LG with circuit MC-84A |
HP 8568B Operating & Programming Agilent • • j111 j112 j113 cnv Philips • fds8876 Fairchild Semiconductor • 2sa1146 Inchange Semiconductor • 2sd1827 Sanyo • pcbmn2 panasonic • tx p42c2b e l pr42c2 panasonic • Compaq Presario 1200 Series COMPAQ • FM-4 Recital FM-5 Brian FM-14 Card FM-44 •
