jd75125
Posted: Mon Feb 21, 2005 3:05 am Post subject: PVY4665RK |
Larry, thank's for the vendor info. I will have no problem removing
and installing parts. Although I have been away from electronics for a long
time, my second career was in HVAC, the Trane Centra-VAC chillers had
micro-processor controls that I did maintance on for Dallas County Facilities and the buildings (60) had electronic controls, which were computer controlled.
I will keep in touch, because the TV is not repaired yet. _________________ Great to meet everyone! |
jd75125
Posted: Tue Feb 22, 2005 6:22 pm Post subject: PVY4665RK |
Larry, I hate to keep imposing on you, but I have been unable to locate any supplier that stock's the 1 ohm 1/2 watt resistor's on the 9-1690 module that are burned(R4162,R4162).
The R3243 is a 110k resister, which I have also been unable to locate.
Any suggestions?
Thank's _________________ Great to meet everyone! |
Larry E Guest
Posted: Thu Feb 24, 2005 1:08 am Post subject: parts |
James, www.tritronicsinc.com they will sell to you as a tech or as a consumer, good people, I`ve used them for years, did you pull
R3243 and check it yet? If you have burnt resistors on the convergence board I would definitely change the stk convergence IC`s. Larry E ps;
If you have any problem getting the parts email me directly at;
[email protected] and I`ll help you find them but tritronics
should have what you need |
jd75125
Posted: Thu Feb 24, 2005 3:53 am Post subject: PVY4665RK parts |
Larry,tritronicsinc on line service says they don't have the resistor's,but
just today I found the resistor's at allectronics.com .The R3243 check's
out ok, but I plan to exchange it anyway. tritronics had the IC's.
Are all resistor's today near equal quality, I know that there are questionable IC's, some without mfg. name and price range is too great.
So I am waiting on delivery of part's,then I will put it all back together and hope for the better.
With your experience and help, probably everything will be ok. I will keep you posted. Thank's! _________________ Great to meet everyone! |
Larry E Guest
Posted: Thu Feb 24, 2005 7:13 pm Post subject: resistors |
you`ll be okay with the resistors, stay with the name brand stk`s,
if R3243 measures 110K 0r 120K don`t worry about it, Larry E |
jd75125
Posted: Thu Feb 24, 2005 11:19 pm Post subject: PVY4665RK IC's |
Larry, what's the deal with STK392-110,STK392-120,STK392-150 and
STK392-180. Are there any internal circuit changes within all of these different part number's.
Are they interchangable for some specific reason, should you use one over another?
I ordered STK392-110, but at the time I wasn't aware of the other version's. _________________ Great to meet everyone! |
jd75125
Posted: Thu Feb 24, 2005 11:20 pm Post subject: PVY4665RK IC's |
jd75125
Posted: Thu Feb 24, 2005 11:22 pm Post subject: PVY4665RK IC's |
Posted: Mon Jul 24, 2006 10:13 pm Post subject: Re: PVY4665RK IC's |
jd75125 wrote: | Larry, what's the deal with STK392-110,STK392-120,STK392-150 and
I ordered STK392-110, but at the time I wasn't aware of the other version's. |
Larry, is the STK 392-100 easy to install? |
