Posted: Thu Nov 29, 2007 11:24 pm Post subject: |
392-110's-392-150-392-180-394-160. All are good. |
Litherish
Posted: Fri Dec 14, 2007 3:21 am Post subject: |
I replaced the STKs with 150s, but when the TV is turned back on all I hear is a clicking noise from the left component board like it is trying to turn on? No picture or sound. |
Posted: Fri Dec 14, 2007 11:15 pm Post subject: |
Did you check the resistors? |
Posted: Sat Dec 15, 2007 1:09 am Post subject: |
minnie wrote: | Did you check the resistors? |
I checked them all, I couldn't see any discoloration or blisters.
The TV did work before I replaced the STKs, the color was just off, but now that I replaced the STKs it just keeps clicking. The job was a bit sloppy though, so I'm getting some desolder wick and doing it over. |
Posted: Sat Dec 15, 2007 11:10 pm Post subject: |
Put new IC's in again and check F850 and F851 5 amp pico fuses, you may have toasted them if you solder blobbed. |
Litherish
Posted: Sun Dec 16, 2007 11:25 pm Post subject: |
minnie wrote: | Put new IC's in again and check F850 and F851 5 amp pico fuses, you may have toasted them if you solder blobbed. |
I checked F850 and F851, they both look good. I'll put the IC's back in and hopefully that will fix things... |
Posted: Sun Dec 16, 2007 11:54 pm Post subject: |
You have to check them with a meter, looking won't tell you everything. They may look ok but their open. |
