terry .o Guest
Posted: Sun Feb 20, 2005 1:06 am Post subject: phillips tv 32 in |
| model 36fl1890 79r has excess of blue & weak red there are no trim pots as far as i can see to adjust on vid ok watchable on tv signal to green |
melw Guest
Posted: Sun Feb 20, 2005 8:27 pm Post subject: color |
| These adjustments are now made electronically thru a service menu which are best left to a qualified tech. Accessing the service menu can change other things which will only make matters worse. You might want to check out www.FreeFlatScreens.com/?r=10948674 for an opportunity to earn a free replacement for this set with a little dffort on your part. |
THE GREAT OZ Guest
Posted: Sun Feb 27, 2005 3:21 pm Post subject: PHILLIPS TV TROUBLE |
HELLO, Boy this guy just wants to sell sets!! Well PHILLIPS is probobly the worst piece of junk ever made however the manual for this model can be purchased through TREASURE CHEST . COM this for those who don't know is a service manual reseller and the paper or disc is approx $55 Any bonehead can follow the book and with a little practice and the knowing that the tube will not reflect the actual service menu numbers you will be able to correct the beam current and cutoff rate of the guns, This is of course if the system is not a total shitbox OZ  |
Posted: Tue Jun 13, 2006 2:41 am Post subject: Re: phillips tv 32 in |
| terry .o wrote: |
Photonics Connector Care Effects of Dam • Samsung_BN44-00265B_[SCH] Samsung • b3x70u Philips • ct-5038vc samsung • TROUBLE LG • HK-6100 Ver 2 Harman Kardon • compal la-7092p r1.0 schematics acer • bfq131 1 Philips • HP DV3 CQ35 LA-4731P R10 DIS 0216 Compaq • DK RELAYS Keithley •
