janders
Posted: Tue Sep 04, 2007 7:11 pm Post subject: How do I determine pinout of integrated vga header? |
| I'm pretty much lost when it comes to this stuff, but I am trying to attach a standard DB15 monitor to an older 1U piece of equipment that wasn't really designed to have a monitor attached to it (if it makes a difference, it's an old, out of service Cisco CE560 that I am trying to convert into a Linux server). It does have an integrated video card and I found a 16 pin header on the mother board that appears to be video out. Using what I found here: http://pinouts.ru/Video/VGA15_pinout.shtml , I was able to find the R, G, and B knowing that they are all 75ohms, and I found these on pins 1, 4, and 7 of this header. My problem, however, is that I am a little unsure how to figure out what I should look for to try to trace down the rest of the pins on this header. What pins are "essential" for basic VGA output, and how can I track them down? I realize that I am going to need HSYNC and VSYNC for sure, but how can I tell which pins that they are on? Any help would be greatly appreciated! |
Posted: Wed Sep 05, 2007 8:10 am Post subject: |
So, you have identified the RGB signals, that is a good beginning.
Then, check out which pins in the header that are grounded, that is probably several ones as it is common practice to have a separate ground pin for each of the RGB signals. It is easy to do by resistance measurements.
To figure out which pins are used for H and V sync, it is best to check with an oscilloscope. At the same time, check out the signal levels. In some cases, it might be TTL or CMOS levels, in other cases, it might be 0,3 or 1,0 V p-p.
Other pins in the header might be "monitor ID pins" according to old IBM VGA standard, or an I2C bus according to modern VESA standard (DDC). |
janders
Posted: Wed Sep 05, 2007 11:05 pm Post subject: |
Vtech,
Thank you for your assistance. Good find from the Cisco site, I never even noticed that due to the fact that I don't have the AV model. I'm sure the motherboard is probably identical however. I didn't even consider that this may not be a VGA header, but instead be composite video. Rather than try to output this to a monitor, would it be easier to just dump it onto a television? If so, what else do I need to track down in order to make it work since I don't have the handy front panel composite connector for my content engine? Thanks! |
janders
Posted: Wed Sep 05, 2007 11:10 pm Post subject: |
| torbjorn wrote: |
torbjorn,
Thank you! That is a very helpful guide to get started with. I don't have an oscilloscope available, unfortunately, so I'll see if I can match based off of the signal levels you mentioned. |
Posted: Thu Sep 06, 2007 5:45 am Post subject: |
| janders wrote: |
Vtech,
Yes, ---IF you already have a standard RCA composite video out on back of that unit(as it's shown on the pix?), you should be able to use a standard Tv for the minimum resolution. |
janders
Posted: Thu Sep 06, 2007 4:01 pm Post subject: |
| vtech wrote: |
Unfortunately, my CE does not have this adapter (I believe it is only included on the AV models, which I do not have). All I have is the 16-pin block on the motherboard.
Would researching the video controller on the motherboard help me at all in regard to determining for sure what this is? I did a basic google search, but didn't come up with anything solid. If it helps at all, the chip has the following info on it:
| Code: |
CHIPS
B69000
W69000B4 0216-b
KOREA
K5416
Is this just a lost cause? |
Posted: Thu Sep 06, 2007 5:25 pm Post subject: |
Ok, thought it had the connector
I would not call it a lost cause yet. 69000 series was actually rather advanced in it's time and reading it's application notes should give you ideas---made by Asiliant technologies.
http://www.asiliant.com/69000.htm |
janders
Posted: Thu Sep 06, 2007 7:22 pm Post subject: |
| vtech wrote: |
vtech,
Once again, very nice find. You seem to know how to find all the good stuff . I'll dig through all of that and see what I can come up with, looks like it may take me some time though. Thanks again! |
hitechtalent Guest
Posted: Sat Nov 27, 2010 9:53 pm Post subject: Content Engine VGA |
| Are you still looking for the 16-pin IDC to 15-pin VGA mapping? |
CRM57R Clarion • CL2560 Hitachi • Panel CMO N156B6-L0B 8 [DS] . Various • 2sc4402 . Electronic Components Datashee • QM16.1L la Philips • DVDR3575H SI 1203420978 Philips • Stereo Clipper 3210 Nordmende • President U536 Unica • DV-525 Pioneer • RF263AE Fast track R1 optimized Samsung •
