Frank Guest
Posted: Fri Dec 28, 2007 11:40 pm Post subject: CT32D10B |
| Hi guys, i have here a CT32D10B, that has this strange behavior like pic is good, but till it gets warm has this high volts arcening, i thought it was bad solder connections then i soldered everywhere but no avail,i suspect the flyback, and tube, it seem a little weak cause when adgusting G-2,and focus i get that arcenig ,and when taping does that too, but only till it gets warm ater that it doesn't, tv is 12 years old i guess it seems going down,any ideas thanks. |
The TV Guy Guest
Posted: Sat Dec 29, 2007 9:05 am Post subject: Arcing till tv warm |
| Hi Frank- suggest you check; B+; electros from ps to hoz; ihvt; hold down caps;pic tube for s/c- check eht correct also. regards ttvg. |
frank Guest
Posted: Sat Dec 29, 2007 7:26 pm Post subject: Re: Arcing till tv warm |
| The TV Guy wrote: |
Thanks Guy for your response.you may be right about caps,i should check those next. the set is at the customer's now,funny thing is when i had the back out it did not make that line pairing unless i turn the knobs on the flyback pots.or tap around the fly.as soon i put on the back cover there it starts to do that but just when cold. this intemittent faults get me crazy.it would be easier if components go dead.i suspect also the customer is getting a good excuse to buy a LCD.he doesn't want to spend much money on a 12 year set . |
Philips LX452AB Philips • imageRUNNER ADVANCE C5051/C5045/C5035/C5 • xv-z1e_a-sm Sharp • pe1520 Philips • 65883-WW-1 MAKITA • 673 PHONOLA • 2sa2205 Sanyo • planatron_pw_110-520_9_palplus grundig • 2n5781 Semelab • OEM 715G2986 [SCH] . Various •
