HandyMan
Posted: Mon Mar 21, 2005 9:58 am Post subject: Philips Brilliance 181AS LCD TFT monitor with dull display |
Hi everyone,
Perhaps someone would be kind enough to offer me some advice... I repair electronic equipment but am still learning more about the inverters used in LCD displays. Although I have repaired them before, I've now come up against a problem for which I cannot find the solution.
This monitor is actually mine. A Philips Brilliance 181AS 18.1" TFT LCD monitor. Using a TDK TAD383 4-output inverter board, running on the 18V input to the monitor. It displays a good image, but the white seems off-colour. When compared to other LCD monitors, the whites on the others seem bright and fresh, but this one seems grey or yellowish in comparison. Perfectly usable, but not as bright as I would expect, with both brightness and contrast set to maximum. Colour temperature settings make no real difference.
I had originally had no backlight which was due to the inverter board SMD fuse being blown. It was a 3A fuse but no fault could be found. Current consumption is 1.6A currently when board is fully working. It feeds 4 lamps and so has four outputs, two either end of the board, each having its own circuitry but with one driver IC for each pair of outputs either end.
There seems to be at least one transformer squealing on the board, although this stops if the lamps from one end of the board are disconnected. Maybe this is associated with the dullish display? When those two lamps are reconnected and that half of the board starts up again, the squealing returns and seems to be coming from all of the transformers on the PCB. Touching the cores with the tip of an insulated screwdriver gets sparks as I would expect, but touching one particular transformer gets the sparks and then that half of the circuit immediately shuts down, but this doesn't happen with the others. Makes me wonder if something is wrong and altering the flux of that particular transformer (by touching with tip of screwdriver) is doing enough to cause the circuit to shut down because it isn't stable or is only just within operating parameters?
I am planning to swap that transformer with another on the board and see if touching the alternative transformer in that part of the circuit still makes it shut down, or if this behaviour follows the transformer which is currently shutting things down when touched.
Does anyone know if the high-frequency squealing and dullish display are linked, and if so, what may be the cause? Is touching that transformer and having the circuit shut down anything to do with it, or is it just likely that it may be more susceptible?
I'd like to have this working properly, as it's supposed to have the best brightness output of its class and is huge.
Many thanks to all.
James |
Posted: Wed Jan 18, 2006 9:52 pm Post subject: |
I think it driver problems
my scree 181as was fine.............i moved it to another pc and bam...........dull
cant quite understand it  |
HP 8568B Operating & Programming Agilent • • j111 j112 j113 cnv Philips • fds8876 Fairchild Semiconductor • 2sa1146 Inchange Semiconductor • 2sd1827 Sanyo • pcbmn2 panasonic • tx p42c2b e l pr42c2 panasonic • Compaq Presario 1200 Series COMPAQ • FM-4 Recital FM-5 Brian FM-14 Card FM-44 •
