ranco Guest
Posted: Wed Jan 16, 2008 2:19 pm Post subject: need service manual for yamaha DSP-A780 |
| Hello j need service manual for yamaha dsp-a780 that no power on. |
ges Guest
Posted: Sat Aug 22, 2009 2:24 pm Post subject: Re: need service manual for yamaha DSP-A780 |
| ranco wrote: |
[b]please someone can help me,j need schematic diagram for amplifier yamaha modl DSP-A780
Turn on 1-3 sec and shut down
Thanks in advance.[/b]  |
DSP-A780 Guest
Posted: Thu Oct 28, 2010 6:29 pm Post subject: protection mode |
MODEL DSP-A780
TYPE SYMPTOM/REPAIR
SUBJECT PROTECTION
SYMPTOM: UNIT GOES INTO PROTECTION AND TURNS OFF APPROXIMATELY 4 SECONDS AFTER TURN-ON. ALL AMPLIFIERS CHECK OK WITH NO DC OFFSET OR OVER-CURRENT.
CAUSE: ONE OR MORE AUDIO MUTING TRANSISTORS (Q408,409,411, 413,415)HAVE BECOME LEAKY. DURING THE FIRST 3 SECONDS, THEY GROUND THE AUDIO PATH. SIMULTANEOUS WITH THE SPEAKER RELAY CLOSING, THE MUTING TRANSISTORS ARE TURNED OFF BY APPLYING APPROXIMATELY -14 VOLTS TO THE BASES. IF THE TRANSISTORS ARE LEAKY B-E, A HIGH NEGATIVE DC VOLTAGE APPEARS ON THE AUDIO PATH, SENDING A -DC TRANSIENT THROUGH THE AMPLIFIERS. THE PROTECTION CIRCUIT SEES THE DC AND TURNS OFF THE UNIT. THIS TRANSIENT CAN BE OBSERVED WITH A SCOPE AT THE OUTPUT OF EACH DEFECTIVE CHANNEL.
SOLUTION: REPLACE DEFECTIVE TRANSISTORS ONLY WITH THE ORIGINAL TYPE 2S1915 (VK432900). |
HP 8568B Operating & Programming Agilent • • j111 j112 j113 cnv Philips • fds8876 Fairchild Semiconductor • 2sa1146 Inchange Semiconductor • 2sd1827 Sanyo • pcbmn2 panasonic • tx p42c2b e l pr42c2 panasonic • Compaq Presario 1200 Series COMPAQ • FM-4 Recital FM-5 Brian FM-14 Card FM-44 •
