middletondj Guest
Posted: Wed Jan 30, 2008 2:37 am Post subject: yamaha pc2002 right channel sound |
| i recently bought a yamaha pc2002 amp that is quite old. the right channel seems to fade in and out with static and does not maintain a constant volume, although if wiggled the right way will work fine but soon dies out, the left channel works perfect. any ideas? |
Gravityboots
Posted: Fri Feb 01, 2008 8:25 pm Post subject: Key words in your statement |
Old: Probably had very little maintenence
Wiggle and it works: Loose connections
Not mentioned: Heat, where there's power, there's heat and where there's heat, cracked connections are sure to follow.
Start there and then get complicated after. |
middletondj Guest
Posted: Sun Feb 17, 2008 10:58 pm Post subject: |
| I have tried this, and all connections are good. if leaving it it will get to proper volume, stay for 5 minutes then go back to fading in and out. If the mixer is turned down and low input level it sounds fine but when the mixer is turned up the problem will be prominent. I have tried multiple mixers as well so it is not that, or the cd player, have used laptop etc. |
Posted: Sun Feb 17, 2008 11:29 pm Post subject: |
| Buy some contact cleaner and spray the stems of the control knobs. |
