gehrig
Posted: Thu Apr 17, 2008 10:22 pm Post subject: |
I meant.. just remove the emitter leg and check B and C.. |
gehrig
Posted: Thu Apr 17, 2008 11:48 pm Post subject: |
Hey.. just an udpate.. here are my voltage readings off of the transformer.
Posted: Fri Apr 18, 2008 5:30 pm Post subject: |
Sorry I meant with Q13 removed place the probes on the print of the pcb where the legs would go if it was still installed.
Regarding your update voltages it seems to be a drop of 40v going somewhere. If Q13 was removed and you remeasured these points it would prove Q13 was doing this. |
gehrig
Posted: Fri Apr 18, 2008 6:43 pm Post subject: |
I see. Thanks for the info. I will give it a shot this weekend. |
Posted: Sat Apr 19, 2008 12:25 am Post subject: |
I pulled the collector on Q13 and powered on. The voltage reading jumped from 30 to about 70. So, thinking Q13 must be bad then? I have one on order..so thinking maybe I shouldn't try anything until I replace. What do you think? |
gehrig
Posted: Tue Apr 29, 2008 12:22 am Post subject: |
It was Q13.. I replaced and everything is up and running.
Thanks for the replies! |
