rholly1975 Guest
Posted: Tue Apr 22, 2008 5:54 am Post subject: Samsung TV Model CT-3329V need repair help |
| I have this old tv, when i turn to channel 1 up to 13 there is only raster. No sound, no video while channel 14 and up is working perfectly. I tried to re-solder all parts inside the tuner but still the same problem occurs. I check also the IF located in circuit board but still intact. Is it tuner problem? pls help. tuner number is TECC1880PA09C(S). There's 2 IC inside the tuner one is TD6359p and the other i think belongs to clock because i cant see the part number.. pls help |
Posted: Tue Apr 22, 2008 9:23 pm Post subject: |
Sounds like a problem within the tuner (lost lo-band). While there is a possibility of the PLL (TD6359) causing the problem, there is no sure way to tell before hand and it may be sometning else within the tuner.
A lot less headache to change the tuner--if it's worthed? |
rholly1975 Guest
Posted: Thu Apr 24, 2008 1:55 am Post subject: Re: Samsung TV Model CT-3329V need repair help |
| thanks vtech[b], may be the tuner need to be replace because i do replaced TD6359p by new ones but the problem still there |
Posted: Thu Apr 24, 2008 4:12 am Post subject: |
| Then, it has to be something else in the tuner's "low band" circuitry. |
naamloos Samsung • CK20T3VR5C Samsung • h3f 41 t Philips • 1470 LG • n4g 40 t Philips • LX2802 Bang & Olufsen • TLV-1491XK Roadstar • FWM997 Philips • philips mcm700 Philips • NHM3-021 NOKIA •
