yangandjiao
Posted: Wed May 07, 2008 1:20 am Post subject: AT49F002T-50TC data |
Features
• Single-voltage Operation
– 5V Read
– 5V Reprogramming
• Fast Read Access Time – 55 ns
• Internal Program Control and Timer
• Sector Architecture
– One 16K Bytes Boot Block with Programming Lockout
– Two 8K Bytes Parameter Blocks
– Four Main Memory Blocks (One 32K Bytes, Three 64K Bytes)
• Fast Erase Cycle Time – 4 Seconds
• Byte-by-Byte Programming – 20 μs/Byte Typical
• Hardware Data Protection
• DATA Polling for End of Program Detection
• Low Power Dissipation
– 25 mA Active Current
– 100 μA CMOS Standby Current
• Typical 10,000 Write Cycles
• Green (Pb/Halide-free) Packaging Option
Description
The AT49F002A(N)(T) is a 5-volt only in-system reprogrammable Flash memory. Its 2 megabits of memory is organized as 262,144 words by 8 bits. Manufactured with Atmel’s advanced nonvolatile CMOS technology, the device offers access times to 55 ns with power dissipation of just 137 mW over the industrial temperature range. When the device is deselected, the CMOS standby current is less than 100 μA. For the AT49F002AN(T) pin 1 for the PLCC package and pin 9 for the TSOP package are no connect pins. To allow for simple in-system reprogrammability, the AT49F002A(N)(T) does not
require high input voltages for programming. Five-volt-only commands determine the read and programming operation of the device. Reading data out of the device is similar to reading from an EPROM; it has standard CE, OE, and WE inputs to avoid bus contention. Reprogramming the AT49F002A(N)(T) is performed by erasing a block of data and then programming on a byte-by-byte basis. The byte programming time is a fast 20 μs. The end of a program cycle can be optionally detected by the DATA polling feature. Once the end of a byte program cycle has been detected, a new access for a read or program can begin. The typical number of program and erase cycles is in
excess of 10,000 cycles. The device is erased by executing the erase command sequence; the device internally controls the erase operations. There are two 8K byte parameter block sections, four main memory blocks, and one boot block.The device has the capability to protect the data in the boot block; this feature is enabled by a command sequence. The 16K-byte boot block section includes a reprogramming lock out feature to provide data integrity. The boot sector is designed to contain user secure code, and when the feature is enabled, the boot sector is protected from being reprogrammed.
Posted: Thu May 08, 2008 1:29 am Post subject: |
| Nah, it is the same chinaicmart ripoff bastard that keeps posting under different names. All they do is to copy other manufacturer's legit application notes to hide behind & quietly keep up their advertising with a link at the end. |
Poblizo.com : ïúòåøåñòâèÿ -
