Larbo
Posted: Thu May 22, 2008 4:12 pm Post subject: DVD tray not working |
My son has a Toshiba TV with an integrated DVD player. The tray will no longer open (with a DVD stuck in it) and if he hits PLAY pr TV/DVD, the picture is garbled, kind of bent and rolling vertically in multiple bars.
So, I opened up the TV hoping to find something obvious like something stuck or broken in it. No such luck. He is what I did find...
1. When you press Open/Close, the TV powers up the DVD spindle operates (searching for a disc?) but no tray activity at all.
2. When you manualy open the tray with the exposed gear and the power is on, nothing happens at all. Tray moves freely.
3. If you power up with the tray open via #2 above, the tray closes
automatically. No response after that.
4. I jiggled all of the related connectors to the DVD player (just in case)
which is made by Orion BTW.
Does anyone have any pointers besides that of a good TV repair shop?
Thanks, Lar |
Posted: Fri May 23, 2008 5:46 am Post subject: |
If it's the one I'm thinkin of.....That Orion design was probably the cheapest load of crap I've ever had to deal with. Instead of having seperate motors, it used ONE friggin toy motor to load the tray, spin the disc & drive the laser mechanism by means of plastic gearing. (whoever came up with that design shoulda been shot)
There was a bulletin put out by Tosh(w/pix) which may help in checking the mechanism but it would be a matter of time before they all failed with no seperate parts availability(part of the course). Any needed part, had to replace the entire mech
Can't say for sure if it's alignment issue but you may have syscon problem & don't be suprised if it's not worth it (the typical nowadays)
anyways..here's the bulletin if it helps any
http://www.mediafire.com/?z2v2jlmtmc1 _________________
Larbo
Posted: Fri May 23, 2008 2:15 pm Post subject: |
Thanks vtech. This mechanism appears to be pretty different. The tray motor does appear to be dedicated with a single belt to a drive gear that shows in the front of the mechanism for manual tray operation.
Is the the fact that the Toshiba DVD screen is broken up like that at idle say much?? |
Posted: Fri May 23, 2008 7:11 pm Post subject: |
Ok, must be a differnt one & yes, if the DVD screen is broken up, there is definately an electronic problem. Could be anything from a bad memory or a signal process issue within the signal board. Remote possibility of a bad connection (unlikely).
If accessable, try pressing against the DVD signal board--any change in the broken DVD screen? if so, you proly have a connection issue somewnere on the signal board. _________________
Posted: Fri May 23, 2008 7:59 pm Post subject: |
| Whats the model #? |
Posted: Fri May 23, 2008 8:16 pm Post subject: |
| Model MD20F12 |
Larbo
Posted: Sat May 24, 2008 1:09 am Post subject: |
Model MD20F12, verified.
However, you got me to thinking about parts and I found on the Vance Baldwin site the model and part!! Bass-ackwards, the part (72783471) can also be found on Parts Depot, too. Since it is about $40 vs $58 on your part, it must be an even cheaper DVD assy. It might be worth the investment... but, do we know that the problem at hand in definately in the DVD assy? |
Larbo
Posted: Sat May 24, 2008 3:08 am Post subject: |
I also wanted to ask....
If I did buy the new DVD assy, does it just "go in" or will I need a scope or something to make adjustments?
Thx, Lar |
Posted: Sat May 24, 2008 5:00 am Post subject: |
(72783471 is the correct number for mechanism--only)
wait a sec;
Most manufacturers sell their DVD mechs complete(mechanism & all electronics) & if that was the case with Toshiba, I'd say to change it & be done with it.
However, unless it has been changed, Toshiba never did so & you had to order them seperate which brings me to the next point:
While you may infact have a problem with the mechanism but I thought you mentioned that the DVD menu was broken/pixlated/distorted sitting at idle right? That is usually a dead giveaway indicating a signal process issue which locks up the whole process--perhaps I misunderstood?
I can assure you that NOTHING mechanical or in the mechanism could possibly cause a "broken menu" syndrom on the screen. So If that is the case, replacing the mechanism is not gonna do it.
Btw, replacing either mech or it's signal board won't usually require any adjustments |
